- Another one bites the dust
- Want To Build my Block any advice?
- My APS TT G35 build is almost complete...
- Basic VQ35DE built
- manual boost controller reliability
- Built motor members. Setups and feedback wanted
- piston to cylinder clearance
- Turbo Oil Feed - Will This Work?
- found this ebay deal
- lean now misfiring
- I was under the impression that intercoolers where in front for maximum air flow??
- custom u headers before building actual header
- GTM turbo kit feedback thread
- Redline Time Atack: Join Forged at CMP on Aug 7-8th
- Looking for R4 software
- head gaskets / head bolts?
- Powerlab Install Complete
- Forged Performance: 5th Consecutive Podium Finish at Nashville Redline Time Attack
- misfiring under boost
- APS used to have 2.5" downpipes right?
- Is a double pass radiator worth it?
- No Throttle(help plzzzz)
- Gamer Modz Build TT 4.5 Stroker
- The official OCgay35 fail thread
- BUILT GREDDY TT and Stock Exhaust
- Haltech vs. Osiris for my vortech build...
- boosted and lasted
- Momentum Peroformance Turbo Poll
- hesitation up top around 6k
- Are my Injectors too Big?
- Anyone using AccessPORT exclusively for FI?
- Clutchmaster FX400 owners, question for you.
- squires turbo sts turbo kits
- Powerlab or SFR?
- Custom Top Mount Turbo
- JWT 700bb Water not run to turbos??
- Who's car is this?
- Knock off Garrett turbo's......beware
- Curiosity regarding 0-60 (FI guys help me out)
- Fuel leak on RFS
- Turbonetics ST and Greddy TT ?
- Have a water/meth kit? Come in here...
- Cable TB swap
- Need a few pics if you don't mind. Greddy TT owners only.
- 350z power transistor
- S&R Performance
- build question
- First G35 to break the sound barrier
- My 2003 g35 coupe vortech install
- Valve issues during rebuild: how common?
- After turbo rebuild still smoking!
- Turbo Kit 350z
- Possible blown turbo?
- 1st FI UOA
- my compression test
- Is my turbo dieing?
- Defi 60mm Gauges vs oem gauge pod, yes I've searched!!
- twin trubo g35 fuel problems?
- Z33Art V2.0 Custom Single Turbo
- Forged Performance: On the cover of Modifed Mag:Tuner Shoot Results!
- Temprture with darton sleeves
- Forge Actuators for APS TT - Yellow or Blue?
- questions on injectors
- My VQ35HR Build
- greddy 20G vs APS Extreme vs SFR
- tial vs TN evolution
- woah, whos car is this?
- Cooling System Upgrade Recommendations
- what you prefer
- TN wastegate pipe cracked again (help)
- air to fuel ratio problem
- Part 3: Uprev is Fixing and tunning my SC Z...
- How fast is the Injected Performance 350z?
- Kinetix Velocity Manifold + Vortech Numbers
- Calling all engine builders with Cosworth components experience
- Which K&N filters for Nismo CAI?
- Hks RPM Range?!?!?
- greddy turbo
- aps tt and rebuild?
- My FI woes...a little help from my friends :(
- HKS VS Stillen
- Catch can problem
- Is it a spark blow out or is my ECU messing with F con v pro?
- Greddy twin turbo over heat. HELP!!!
- hks ssqv bov install on a greddy tt kit
- My Vortech 2.87 setup & dyno numbers =)
- Question about 06 hi-rev motor?
- boost controller
- Info on a good price
- *Ultimate Performance opens in South Fla.*
- Leaking output shaft seal.. anyone else?
- Why you should do your own wiring
- Looking to buy this car...procharger..
- The official lawchick fail thread
- Holy crapballs, am I screwed? Need opinions.
- Koyo double row rad VS PE intercooler from TT kit
- what ecu do you have
- max boost on 1 BOV??
- Huum....
- Garrett turbochargers from APS
