- AEM Dyno-Shaft
- VQ Audiophiles: Lend me your ears...
- turbo kit on ebay??
- G35 and 350z same Vortech kit?
- Vortech V3 with Osiris Tune Dyno
- APS Inline Turbo Oil filter
- Powerlab owners: what exhaust?
- Missing MAIN HARNESS FOR HKS AFK KNOCK AMP version 1
- HKS Knock Amp Manual version 1
- How much boost?
- I/C Discussion
- upgrading the greddy twin turbos wheels
- Fuel Pump Recommendations for Vortech install
- My Greddy twin turbo build
- Holset turbo thread
- Ways to improve HP and cooling. Worth it?
- Deciding on a Turbo System!!!
- overheating under boost, but not load
- Retune @R/T Tuning, dyno + track slip inside
- used turbo kit
- Vortech S/C Belt Snapped - HELP!
- APS TT actuators replacing, wastegates
- remove or oem thermostate???
- Boosted Performance 6765 g35 628hp/561tq at 22psi
- AWD 380Z TT Completed
- exhaust leak?
- HKS Traction Fluid V Rotrex Traction Fluid
- Hay JEFF, Like I Said, It's Always Something
- Exhaust for FI 350z help!
- vortech v3 full kit
- thatv35guy’s PowerLab ProEFI Motor Build, Pic Intensive
- Billet 76mm turbo experiment
- 5 at sc to gtm tt build
- necessary to thermal coat the manifolds?
- Who's running Vibrant vacuum manifold?
- built auto dyno question
- supercharger questions
- haltech, no throttle response
- In need to have a new Clutch/Flywheel set-up
- Looking @ Different Exhaust for ST
- Vortech - CAI vs Bigger Intercooler
- Street Tires for 550-650whp
- Boost leak opinions would be appreciated
- Aeromotive 340lph fuel pump or DW 300 lph fuel pump
- remove intercooler paint
- my tt build
- MY VTR Build has been completed
- supercharging with high miles
- Replacing wastegate gaskets on greddy TT
- online store not honoring HKS EVC price on website
- what do i need to go fi
- water/meth kits, what kit did you use?
- Stillen about to announce HR kit
- wastegate duty vs boost level? what are your #'s
- 350z single turbo tuning problems
- Another momentum build!
- Buying a used Z with FI...
- APS TT part Q
- Question about a catch can
- advice for my FI goals
- IVT help
- momentum gt3794r build.
- 30 psi fuel pressure drop?
- Carbonetics clutch..
- APS Boost controller dranining battery, normal?
- Built engine went pop
- NA to S/C
- Estimated psi with pulley combo with UDP?
- Need help with Engine
- any tuners close to tulsa ok.?
- 844whp@26.5psi
- Intercooler specs on Vortech kit??
- Is the Stage 4 Stillen upgrade worth it??
- Trying to get more HP!!
- Recommended Tires for FI
- greddy turbo rebuild
- Help tuning in nc
- Please help!!! Car overheating
- A little new but I have some piston and turbo Q's
- Spark Plugs for TT
- APS Single Turbo - need more boost
- Greddy tt open waist dumps or not???
- Oil/water feed/drain on Twin Turbo HR.
- Smoking like crazy on deceleration
- Turbo exhaust Manifolds pics
- Nooob Power Question
- Which kit to go with?
- to F/I or not to F/I
- Vortech noise? (Video inside)
- Better mileage after supercharge?
- Performance motorsports in ny. Stay away from them!!
- 2.87 pulley cracked. WTF?
- Upgrading My Fuel System…
- HKs 2530 for the vq35
- Vortech advice (with a twist)
- TUrbonetics kit tuned by R/T performance
- CEL code P0138 and P0158
- UpRev Tuning Question
- do I need a procharger fmu if I'm running turboxs utec
- Radiator Cap
