- headgaskets
- Car dies randomly at an idle
- WTF is going on with my car?
- Rebuilding 18G turbo question
- Autocrossed my car last week......*Vid*
- Random NO Start? Only at Night...
- stock injectors???
- Well I figured out why my IDC's were so high
- Passing NJ Inspection with an F/I Z???
- Spark plug tip and electrode touching!!! ???
- Runs RICH after awhile of driving...
- very happy...
- My Build -- from scammed @ SGP to top notch service @ FORGED & Import Parts Pro
- Turbonetics single turbo
- Greddy Twin Turbo on Stock exhaust?
- MAP Sensor Pressure Conversion Parameters
- cosworth/hks dyno difference
- FI or bike?
- Power steering line cracked next to turbo:(
- walbro 255
- 20g Greddys New Turbo kit = Power!!
- you know what really grinds my pulleys?
- Vortech Supercharger + 50 hp Nitrous shot
- Haltech problem
- Need some help pls...
- Injector install question
- New problem.... Car randomly dies.
- Fuel Injector Latency, or Dead Time, for Various Fuel Injectors
- Oil in compressor/ic pipe
- MOTOR BLEW today
- What cams to use for a built motor with greddy TT?
- MA area installers for turbonetics single turbo kit? Vinny Ten Racing?
- My build..the good, the bad, and the downright awesome
- JAPTRIX For SAA3
- built block piston HELP!
- I'm saving $$, help me choose
- Stock HP question from a real noob
- Do you track your greddy kit?
- My dyno numbers are in!
- ongoing idle problems with vortech
- How many lbs of boost on a stock motor?
- Planning FI build. need advice
- P0011 IVT Control
- Special "THANK YOU" from UAE(dubai) to SAM@GTM
- High amp alternator
- Need Help! Procharger belts keep stredding or breaking (12PSI)
- Vortech BPV
- need help for new built motor
- sts rear mount vs old fashioned tt
- Just little update
- Pics of my Powerlab install
- fuel pump problem
- nos and turbo
- Fixing A Rear Main Seal Leak
- powerlab utec ?
- FI Roadster Counterweight
- HKS CAMP 2 question
- Boost in higher gears
- ****** TTG35forT - Rev 2.0 ******
- Oil pressure sensor pinout?
- Vortech V3 rattle???
- Tool to disassemble harness
- Gonna Be Starting My New Motor Tomorrow...
- Time to boost! Built hks tt
- another FI clutch option: Spec Super twin disc
- HKS CAMP2 User Question
- PE TT vs Vortech SC
- Good Day on the Dyno-442 HP/375 TQ
- chris macellaro
- what will I have to upgrade after HRTT 6-7psi? Recommendation
- How would you know when to replace valve oil seals
- Tüv papers for Greddy Biturbo-kit
- Another Powerlab GT35R Kit Build in process...
- Stock block reliability Turbocharged
- Walbro installed... car stalls on startup..
- Epic turbo set up
- Where to buy fuel filter strainer/filter?
- Vortech + 85 degree = Killed my A/C.
- turbonetics oil in intercooler and intake piping?
- FunctionTuned
- Forged Performance Announces New Website: Version 2.0
- Stillen S/C with 11:1 comp build
- bad vortechs
- Supercharger on Automatic
- Need help with Injectors...
- Gapping Denso Iridium IKH20 for STS kit...
- FORGED PERFORMANCE 2009 2nd Annual Top Dawg Airstrip Event!!!
- GTK vs GT series turbo's
- TT 07 350z problem
- About to go bigger with the gt35r powerlab kit.
- my vortech cog pulley belt broke..
- A Day at Forged Performance: 3.3 VLSD Review & RECON Intel for XKR's +1000hp build
- Experience w/ HKS VBC
- Voretch with 2.87 pulley's
- Crazy Blow Off Valve
- Since my first post in FI went so well......
- AAM 3" dp's + w/g relocation
- can i make 700whp?
- Anyone know where I can get the bottom bucket part of the pump assembly?
- How are your GreddyTT WG's wired up?
