- Powerlab Kit
- Hiccup?
- Just got mytune with 3.12 pully and 440 injectors
- K&N's in place of foam filters
- Went to GRD yesterday and had my Vortech 2.87pulley and new exhaust tune done 414whp
- Gas Smell On full tank ?
- Bad Turbo????
- Aquamist HSF5 and Haltech
- How to water cool a tt kit?
- VK56 Injectors & More Boost
- Need opinions re SC purchase:
- Vortech Ceramic thrust 65K
- GReddy 18g v. 20g. for 600whp?
- Will RC 440cc injectors work with stock ECU
- Go Big Or Go Home!! PPIHC 928 '09
- How does your significant other feel about your FI investment?
- Wiseco Opinions
- how to tell when turbo seals have gone bad?
- Vortech leak...where?
- intake mani
- Trying to change out my 3.12 pulley from my Vortech and its hitting the blower unit..
- Has the recession affected FI Builds and part prices?
- CELs and o2 simulators
- No, I'm not going to turbocharge it... My TT G35.
- Who's knocking....Oh nevermind that is my motor
- Vortech and CARB in Cali
- Proparts boost gauge
- Advice needed! Pull motor or not???
- After stalling car...Limp Mode...flooded engine...or both?
- Power and damage to wheel stud question
- Need some references for a good shop
- forced induction VS. preformance and cost effectiveness
- New Supercharger Coming
- Retune + Meth: Pics and video
- Windshield washer capacity for Meth
- Help! Need power steering fitting!
- Vortech / HKS / Stillen idle sound, loud???
- EGT Exhaust Gas Temp Gauge probe location
- BIGGGGEST NOOB question ever ????? RIGHT HERE...HELp
- Supercharger guys, what do you think about sand blasting pulleys?
- Problems with radiator fans, help!
- Greddy TT finally tuned!
- Koyo 53mm in a Greddy TT car?
- Haltech Auxiliary two-step rev limiter ???
- >>> very sick drag build <<< 2000hp ++
- Going F.I. - opinions needed
- Where can I find Banjo Bolts? (OIL FEED LINE)
- Twins and SFR 5AT
- aps tt o2 sensor?
- smalltuners |DevilŽ| is back !!!!
- TIAL 50mm Q BLOW OFF VALVE BOV
- OEM injector wire clips
- More 9 second passes in our Z
- ECU throttle codes
- Twin Turbo Fender Emblem
- pre-FI mods
- Turbonetics vs. Vortech need your opionions!
- Finally!
- Boost drops every 2 - 3 months
- Best fineal drive for drag..
- So i wake up this morning.. and look what i find
- my build
- Seimens Injectors help
- Dropped my motor off at SP!
- Turbo Timer recommendations?
- anyone use one of these??
- Crash Bar for Greddy Kit
- Greddy EvoTT vs Ti-C
- Stock Knock sensor throwing codes
- Someone make a comment on this $645.00 ebay turbo kit!?!?!
- greddy emanagement questions
- 350z Greddy TT Kit installed and tuned
- Bigger Injectors and Fuel Mileage/dte meter
- injector questions
- How much can you slip a 6 puck clutch??
- colder plugs
- HeartBreaker Dyno #s TT 350Z
- brake booster and boost
- Wiring Diagram
- wideband or EGT?
- Overdrive/JtranStudios Introduction
- Expected performance...a little dissappointed
- G35 Greddy 20G TT Install
- Oil pressure at idle
- built head problem..... pics and vid inside.
- Timing Cover getting powder coated..anything I should be aware of?
- TN kit air filter
- Experience with Vortech and HFC's
- Shop Wall of Shame
- Hey Guys Check Out Meh Car!
- smoking problem after turbo system install HELP!!
- Did a boost pressure test, what is making this sound? *VID*
- "Hiding" a single turbo kit in California?
- Be careful picking a shop
- VK motor mated to Altima transmission in mid-engine config - POSSIBLE?
- APS 3.5" Test Pipes on APS Twin Turbo Kit: HELP
- Just wondering ..
- Competition Stage IV Clutch/Flywheel Installation Problems
- FI Twitter anyone?
- FI and exhaust size
