View Full Version : Forced Induction
  1. Anyone use Osiris when FI?
  2. powerlab gt35r
  3. AEM Peak and hold injector driver
  4. Greddy TT owners
  5. Any Reason Not To Go .040 Over?
  6. unichip for tune a vortech sc
  7. Heat Dissipation: Stock OEM hood vs your aftermarket hood
  8. quick question about sts turbos systems
  9. Doing it for the wrong reason???
  10. Vortech Rebuild
  11. current non-sleeved highest power?
  12. vortech tune
  13. sc vortech question
  14. Starting Issues
  15. Turbo LS2??
  16. Idle relearn is not working!
  17. Oil on Vortech output pipe.
  18. Stillen S/C clearance
  19. Calibrating the External MAP Sensor on my Haltech
  20. GTM 3.8 stroker kit break in. with JWT TT
  21. Egt question
  22. car goes offf
  23. Overboost help...
  24. cluch for vortech
  25. Where's the VQ35HR SC kit?
  26. TDC
  27. APS ST and EMS/Uni-chip question
  28. Slow power drain...result of aftermarket parts?
  29. Thanks To Everyone Who Helped
  30. PC'ed pistons and rods for more power, lower heat and better tolerances?
  31. Anybody got ATI 12psi pullies? and upgrading intercooler question!!
  32. Forged Performance!!!
  33. So... has anyone just put 2 breathers on their valve covers?
  34. engine rebuild, over 600hp. share ur experience/knowledge
  35. Turbonetics Build Block
  36. High HP twinned cars
  37. deatsch werks 600 inj impedance
  38. APS TT Tuner Kit(D.I.Y install) + Haltech = The Injected Experience
  39. Check Engine + TCS + SLIP Lights?
  40. Greddy Turbo Rebuild
  41. Just some small TT questions
  42. Vortech with 650cc injectors
  43. BB turbo's VS. jurnal bearing turbo's
  44. Who does their own Compression/Leak down tests?
  45. What PSI for 400whp in a Greddy TT?
  46. Burning oil off of drivers side exhaust?
  47. Forged Perfomance expirence!!!
  48. Intake manifold VS spacer for S/C
  49. Exhaust soot all over my rear bumper, common issue?
  50. ITB with air box !!! woow sick
  51. Block Gaurds?
  52. rear-mounted turbo, single turbo or vortech
  53. Strange Boost Creep Problem.
  54. Power Steering melted by Greddy turbo!
  55. Twin Turbo sizing when using stock block
  56. Need a vortech pulley part number ...
  57. GT42R vs Greddy TT
  58. Anyone here using a STS rear mount turbo?
  59. Twin Turbo Kit Questions
  60. Boost loss after 6k rpms - timing issue? UTEC/Cipher data attached...
  61. Carbonetic Throwout Bearing Replacement
  62. Who runs a Vacum Manifold
  63. Feeler on Custom External Swirl/Surge Tank
  64. FI guys.. underpan?
  65. Greddy 18G Twin Turbo
  66. code p0057
  67. My winter project...turbo fabrication
  68. Car Wont Start
  69. Vortech install
  70. Cel 0603
  71. Code 1136
  72. Vortech oil feed
  73. WTF... ??
  74. Aps st....$$?
  75. Factory warranty still good if turbo kit taken off?
  76. going for 600 hp!
  77. Merry Christmas
  78. Haltech Platinum EMS for 2007+ 350Z with VQ35 HR Engine
  79. Greddy Twin Turbo kit problems
  80. Vortech oil drain
  81. Td05-18g oil return gasket????
  82. Switching Engine Harness
  83. APS Single Turbo Question
  84. CJM twin pump question
  85. supercharger question..
  86. Getting A Carbonetics Clutch Balanced
  87. AAM Billet Crank Girdle w/ Integrated Windage Tray
  88. Just had to drive home in a Blizzard...
  89. JT Performance factory
  90. Mystery plug?
  91. Universal Turbo Kit Questions
  92. Stillen SC Owners - I need some help - I lost a part
  93. V-2 vs V-3 Vortech
  94. turbo smells like oil
  95. Need help ASAP with turbo!
  96. Vacuum Issue
  97. Vortech or Turbonetics?
  98. Stuck Injector = Huge Problems , ANY IDEAS?
  99. About as CAI as you can get!!!
  100. Im doing a Custom Twin Turbo setup, need input
