View Full Version : Forced Induction
  1. Running decats on the same tune
  2. Question of aftermarket Blow off valve for APS TT kit
  3. boost reference for BCS on TT EWG setup
  4. My Greddy Twins have twins....( or vise versa?)
  5. Car won't accelerate
  6. Help with my Lean spot at 3000-3500rpm
  7. few questions about upgrades
  8. Friend's Custom Twin GTX3076R Build
  9. Thermostat = best cooling mod
  10. VQ35 turbo hr race engine
  11. Stillen Supercharger and Resonated Test Pipes?
  12. Reason Im not getting peak boost in 1st and 2nd?
  13. Speed based tuning
  14. Creating new intake for vortech have a couple questions
  15. Haltech Update, with CAN Input/Output Expansion Box
  16. FI Woes, A Love story.
  17. 650 idle ok for FI?
  18. New Build - Big Thanks to Dynosty!
  19. How to Combine AEM Boost gauge and Haltech
  20. Vortech Tuning, HP/TQ with 600cc Injectors
  21. Going F/I?
  22. Low normal compression question
  23. Total D's 18G build......Finally!!!!!!
  24. Twin 16g setup - Theoretical Question
  25. My long awaited Greddy TT Build list!!!!!!!!
  26. Is this mod list good for F/I ?
  27. Fuel Pressure Gauge - Weird Condition Change
  28. Help Identify Valve ....
  29. Transmission power
  30. Momentum Turbo Plans
  31. greddy tt kit no bov sound
  32. About how safe am I runing on just wastegate springs
  33. Vortech w/ 2.87
  34. need input on street racing
  35. Exhaust: Dual 60mm to Single 76.3mm
  36. Not a VQ35 but... 900+ WHP on E85 inside.
  37. fuel pressure and boost controller issues (haltech)
  38. Twin external Bosch 044's over kill for 500RWHP??
  39. 2.87 v 3.33 pullies
  40. SC and stock clutch?
  41. Greddy 20g Exhaust HR Nismo TT HELP!
  42. My Vortech Build
  43. thanks for the lols nico club =D
  44. WACKY AFR readings with mypowerlab kit
  45. shop time for install v2 vs v3
  46. sts kit questions
  47. 1200cc inj/ FI build... Ingition amp??
  48. HKS AF/Knock AMP vs J&S Safeguard
  49. why no fuel setups with supplemental injectors?
  50. Spark plug heat range? with pics
  51. Race Gas (C16/ VP import) for motor safety??
  52. New Walbro Fuel pump 800WHP
  53. Is it worth building an engine for a Vortech?
  54. MissFire, No Codes
  55. HKS Oil pan from TT kit question
  56. AutoMeter pillar pod question
  57. Iridium NGK plugs
  58. It time for my Built.
  59. I Need help BAD with my Vortech SC!
  60. Built engine back together: oil temps high
  61. Check valve question
  62. More vortech issues
  63. Vortech running lean. help please
  64. Good FI clutch reccomendations?
  65. Seeking advice from APS gurus
  66. Greddy+UPREV+HR=Amazing
  67. Boost pressure not increasing, stuck at spring pressure
  68. Haltech - RPM Limit Bump
  69. fuel pump issue and cooling for turbo
  70. GTM supercharger AT 350Z
  71. Over heating with A/C on and with warm days
  72. Tuning my car and running into fuel issue
  73. Utec help!!
  74. Need VTC cover nylon ring part number.
  75. figuring rpm #'s from mph dyno???
  76. Insight on Vortech SC
  77. XKR & RAJ - Toast Learning to Drive :)
  78. DE build has started, off truck, on stand
  79. How to make Turbonetics ST more reliable?
  80. 350z tn fi questions?
  81. Vortech Fuel pump question
  82. BC3 Cam owners... Need input.
  83. Loud squeal noise when not in boost and idle
  84. The Ginger's 18G GReddy TT "Build"
  85. GTM stage 1 HR supercharger turn key kit
  86. Question about Ati Procharger
  87. Turbo z studders at 4k
  88. Running lean in 5th and 6th gear??? Built APS TT.
  89. AAM Procharger brace wanted!! Need help please
  90. greddy tuner turbo kit (20g) question..
  91. Planning a TT build. Advice?
  92. Vortech tuning issue...
  93. 350z Coolant Hose Difference? Vortech Related
  94. best place to get a built motor
  95. arp L19's into the block: anti-seize or dry?
  96. Who's car is this
  97. Vortech 650cc utec help please!
  98. Where to buy pre bent cold air intake tube for vortech
  99. Removing idler pulley on stillen s/c?
  100. Vortech rattle help
