- Custom build with GTM tune
- TN High Water Temps ? ? ?
- Warranty for the FI'd guys
- Open to Suggestions
- Oil consumption on FI cars....
- APS with cats
- Have just a supercharger block what else is needed?
- Custom fuel line & return line for the CJM twin fuel pump
- Help Please!!!!!!!!!
- Tranny and diff oil for FI?
- Oil Question!?
- my car build
- should i reinstall my revup lower plenum?
- how much oil/legth of oil level gauge?
- Utec basemap?
- ZdayZ '08 LEO updates......
- Greddy intake and exhaust questions...
- HELP Turbonetics Boost Creep
- benefits of solid motor mounts?
- Coolant Purge Nightmare
- New Vortech tune Performance Factory
- Fuel pump relay?
- Greddy TT Banjo Bolt solutions?
- TN KIT, extras
- How does your GF/Wife feel about F.I. ?
- AEM/FIC vs Greddy E-manage
- Turbo Help?
- blew my motor
- Will you FI your next car?
- Julian doesn't have anything on this... IP 1300whp breakage
- Koyo Radiator With Vortech.
- Congrats Wongy - Feature in Turbo Magazine
- More upgrades = More problems....Car wont rev past 1k RPM!!
- Size of socket to remove oil pressure sending unit?
- My FI nightmare.
- Thank you GTM! Stillen Sucks
- question for you guys....
- Eagletanggreen ----->Thinking about quiting!<------
- AAM basic fuel return?
- My built block turbonetics setup -
- AAM Spec 3 in. Exhaust w/ Turbonetics
- AEM Fuel/Ignition controller
- darton mid sleeve kit with 99.5mm bore
- which product to clean TB?
- My 10 Day Build
- Fi Guys Humor
- Looking for Oil Catch Can for my Vortech.....oil in ic pipes
- HKS Twin Turbo Kit
- Possibility of a Lounge section in F/I??
- Cheapest place to buy EO gasket kit
- Diff nightmare
- plenum,stall?!
- I can't hold idle....HELP!!
- How do you disconnect the Snow Performance quick connects?
- boost gauge not reading boost
- Built motor price f*** up?
- Vortech Revup & Non Revup
- Vacuum @ idle?
- Driving with my Vortech and the cog belt removed?
- Fuel Consumption Question
- 488 whp Vinny Ten Racing
- Vortech for the VQ35HR
- Best idling LARGE injector
- Quick question about boost controller install.
- Finally The Car Is Tuned
- T-Trim on a stock block?
- need help asap
- STS and I couldnt be happier...
- Odd whistle noise from 0 to 1psi boost
- Diameter of the fuel line for 600~700whp application
- Final results......Performance Factory TT build.
- Knock on Revup Running Utec ...
- UTEC tunning problems with vortech
- Quick questions
- Ck eng lite/service engine soon light...ON!
- Procharger dyno #'s 7.8psi
- How do you have your wideband installed?
- I'm confused about this whole fuel system upgrade...
- 2004 G35 Vortech S/C tuned dyno numbers (PICS)
- boost and oil temp gauge install.
- need help with APS extreme twin turbo
- Exhaust fuel odor
- My Stillen Supercharged 350Z
- Finally going to gtm......
- Strange power cut out on hard rpm shifts after motor build
- JWT TT Kit on HKS CatBack
- HKS exhaust
- thinking about putting greddy twins on VQ35HR
- Snow performance vs Coolingmist Vari-cool
- OMFG I blew my Vortech Again
- thinking of FI
- Walboro 255 Install?
- greddy tt coolant reservoir location
- expensive oil change
- Eagletanggreen---->*Ikeya seqential Shifter Video*<------ Finally!
- **HALTECH Review-Stock Block 12 PSI w/ Meth**
- Coolant Coming out around Oil Filter
- Injector size ???
- Pics: Turbonetics G35
- No Roots Blowers :(
