- yet another vortech failure
- G Sedan FI setup
- STS turbo kit, haha good idea, but not
- Vortech Installers In Nw In Or Chicago Area
- Whats a good straight exhaust? i have nismo =(
- Dyno #'s
- HKS Twin Setup Turbo Kits Now Available!!!
- JWT Bypass Vavle
- short block build for s/c and 100 shot of nitrous
- What BOVs are useable with the TN ST kit?
- mmmmm....Titanium valves!!!
- Easiest way to take off 3.33 Vortech Pulley?
- Ceramic Kinetix flowing like the metalic ?
- Best Head Gasket
- TN: Small Oil Leak Around Compressor (Pic)
- People with Oil Coolers, How are you tapping your sensors?
- Si TRIM VORTECH.
- Need Help
- Aps Tt?
- Who runs copper plugs?
- Keep the APS Extreme Fuel System Or CJM?
- Special bearing sleeve for the Carbonetics/ATS twin carbon clutch?
- Finally decided, APS TT it is...
- Turbonetics fuel pump assembly mod
- turbonetics and 06 headlight issue..
- FI and lower compression
- turbonetics exhaust leak
- Need a fuel return, but how much more power do you think I could make?
- Greddy turbo
- What is anti-lag
- GT45R in a Z
- Stock Vortech By-Pass
- Vortech
- haltech vs. proefi
- What do you guys think of a used turbo kit.
- OFFICIAL Vortech Statement (look in here)
- Looking for a shop for a custom build/built motor
- APS TT replacement and upgrade info....
- remove rev limiter, control fuel voltage
- Has anyone tried using a Map ECU II?
- Looking for Advice from Owners
- local shop near ny
- Big Build guys, what is the standard deposit to start work?
- GTM issue
- I never see anything like this before....
- install evo2 exhaust with turbonetics single kit
- Turbonetics reflash to TXS UTEC (Tune at GTM dyno comparison)
- built engine packages
- Too little backpressure = overboost?
- Hot water over FI install...
- Problem with Vortech install. What should I do?
- Official MRC SMACK DOWN thread, you asked for it, you GOT IT!
- can you have a supercharger and twin turbo on a 350z?
- Greddy TT installed by SGP with pics and info
- T-bolt clamps
- Vortech, going on #4
- Problem with APS Turbo kit
- Got the Vortech back in today
- Importpartspro,s built motor,s
- Vortech CAI
- IntensePower / ProEFI / Greddy TT: Closing in on 700whp!
- vortech mounting kit
- 2007 350z turbo
- Advantages of Raising Rev Limiter on 5AT
- Robert_K's JWT TT Build Thread
- header with vortech... not so sure...and Hight flow cats....
- Haltech Platinum Review w/dyno numbers!
- Exhaust Question
- Walbro Fuel Pump questions. Someone please help me.
- vendors...EGT probe...F Con
- Looking for the right kit
- Whats the average 1/4 runs to Vortech Z's Run?
- Need Help With ARC V2 Catch Can Install
- ProEFI / Powerab / Turbonetics: Comparisons w/ VTC on vs off
- Anybody running Skunk2 spacer and Vortech?
- Hks Rotrex Vs Vortech
- Anyone with a HKS Supercharger
- need advices on 2 exhaust system...
- Another one BITES the dust
- Vortech 34 T Cog pulley
- Does the Aps twinturbo kit from the g35 work on a 03 350z?
- looking for some wisdom (forced induction)
- Twin turbo Vs single
- Going TT, list suggestions?
- Signs of Vortech Eating itself
- How High Can The VQ Rev w/ Built Motor and Valvetrain
- Question regarding injectors for whp...
- Im DOOOOOOOOOMed look!!
- Suprastick
- aps tt issue question
- What is my car worth??
- All In One Trunk Mounted Water Alcohol Methanol Injection Systems
- The "Thanks" thread
- JETPILOT Who?????
- is this for real?
- anyone overheated stock valves?
- Average MPG on boosted Z's
- FI Engine build gurus help please.
- Can someone explain Ambient Temp and IAT.
- Vortech fitment question for RevUp owners.
