View Full Version : Forced Induction
  1. external wastegate conversion... is it possible
  2. godspeed turbo kit
  3. Injector install ?
  4. spark plug qustion
  5. Finally got my vortech installed
  6. 3.9 or 4.0 final drive with a supercharger
  7. Proefi users... What's your experience been so far?
  8. Car would hestiate snd lean out under wot .
  9. Wont start after injector install (Vortech)
  10. FI 3.5 to 3.3 FD comparison question
  11. what to do?? need new enginee
  12. Manley Rod Direction?
  13. No throttle response after clutch install
  14. first italian hr with gtm sc
  15. How do i identify a rev-up oil pump?
  16. How long/miles on a TT.
  17. Uprev F/I
  18. Another HKs Supercharger build
  19. High Idle - Suggestions required
  20. deatschwerks injectors o-rings reuseable?
  21. G35C AT / JWT 700BB Take Two... (Noob Friendly)
  22. 2007 350Z HR motor.
  23. Over 55k boosted on twins and running strong!!!
  24. too restrictive an exhaust?
  25. maxed out gt 28's
  26. Has anyone does this, or is it even possible on a Z?
  27. machinist needs info: DE block mod for HR gasket
  28. twin turbo
  29. APS basemap Haltech
  30. UTEC install ??
  31. Torque specs for spark plugs?
  32. Boost & Fuel Pressure in 1 Gauge?
  33. Vortech won't build boost!!
  34. Does anyone have a link to a complete list...
  35. 700+ horsepower, 3 years running strong
  36. Sequential greddy tt setup?
  37. Vortech kit instal question
  38. SUPERCHARGERS with test pipes, ART Pipes and HFC's..
  39. knock
  40. Vortech V3 and final drive gears question
  41. My post deployment F/I build
  42. Old FI crew...
  43. Osiris and base Z
  44. Need Turbonetics Crossover Pipe for Auto Trans
  45. GTM Supercharger Build List
  46. Vortech makes screeching sound
  47. Help: Turbonetics 350z Idle issue.
  48. Took off my upper manifold and here is what I found....
  49. Powerlabs guys - emissions
  50. Turbochargers/Supercharger and automatic transmissions
  51. Quietening down the Vortech V3
  52. Precision Turbo's ALL NEW Website!!
  53. Low boost due to warm weather???
  54. Built 5 AT and RWHP
  55. utech overboost issue
  56. anyone can help...fuel control management box
  57. dead Haltech wideband sensors???
  58. Probably a really stupid qiestion
  59. Motordyne TDX w/ built block and turbos?
  60. APS TT smoking from bank 1 when rev'd at idle.....
  61. HELP! Haltech for 350Z HR
  62. Turbo 350Z Rear Tire Suggestions
  63. Procharger boost levels for stock block
  64. haltech- switching from internal map to 3 bar map
  65. *ATTENTION SHOPS!* What oil do you use & recommend???
  66. a dream no longer
  67. Looking for 3" test pipes
  68. Considering a Vortech supercharger.
  69. Bad idea?
  70. Manifold Gasket - 2 ply vs 3 ply
  71. omg building an engine tech!!!!
  72. Turbo porting
  73. Built HR *Broken Cam* Part 2
  74. Need help oil cap pops off?
  75. Looking for some help..
  76. REV-UP Vortech...crazy results
  77. Swapping Transmission's
  78. Built HR *Broken Cam*
  79. Experience on valve clearence with JWT S7 cams ?
  80. Vortech V3 Oil Leak
  81. Ceramic Coating Turbo Hot Side
  82. 100mm pistons
  83. 4th Annual Airstrip Event (pre-ZdayZ)
  84. Request for a diagram.
  85. Bad o2 sensor?
  86. Resetting ECU with Turbo
  87. single or twin turbo
  88. Need aesthetics advice from FI guys
  89. supertech
  90. HKS 1000cc injectors
  91. Fitting RFS, Pump and injectors
  92. Question I've been wondering about...
  93. need some opinions
  94. Another update to my build : )
  95. HR FI plenum?
  96. na vs boost?
  97. in-tank single fuel pump "veryon" 800whp
  98. Dyno 14psi vs 18psi FWD3.5 Auto
  99. GTM GT3582R twin turbo
  100. Custom Intake for Vortech
