View Full Version : Forced Induction
  1. What oil do you use?
  2. Vortech FMU trouble shooting help
  3. AEM W/Meth injection new installation
  4. High Mileage Boosted VQ's
  5. Stock gears best for FI??
  6. New MAF sensor for more boost?
  7. After 3 years of patiently waiting
  8. Vortech Chirp help?
  9. Vortech BOV fitted to charge pipe?
  10. suggestions on clutch/flywheel?
  11. High Power Build Cheap
  12. Wideband sensor bung location
  13. I Need 600cc injectors
  14. Forged Performance: Momentum Single Turbo Kit preview pics
  15. 600cc vs 800cc max power
  16. What's a broken impeller sound like on a Vortech?
  17. VEI Systems Dual Wideband gauge, review
  18. HKS Couplers
  19. Momentum turbo kit RELEASED!
  20. A must for an FI kit that uses oem maf tube. Treadstone replacement maf bung and tube
  21. p1111 and p1136 is found
  22. Call out for GTM Pulley mod users
  23. How do you guys get such high WHP out of low PSI turbo set ups??
  24. i have a engine problem need help
  25. Lean at low rpm boost
  26. 476rwhp on Stock Block
  27. OEM injectors vs RC440cc
  28. Apexi install help!!!!
  29. WHO SAID CAN'T get Flat AFR'S a Vortech FMU
  30. Compressor Surge APS kit
  31. Blackstone labs
  32. BorgWarner Matchbot
  33. Twin turbo build fabrication/pics
  34. Wideband Controller location?
  35. JDM Joe's HR Build
  36. Normal sound for Vortech?
  37. Need Help, Wont idle, dies on Start up, Vortech SS box bad?
  38. My TT HR build by intec racing
  39. Cams/Compression Quesion
  40. 96mm VQ35DE head gasket
  41. Cog Belt for Vortech 400% Stronger
  42. analyzing new spark plugs
  43. Vortech install = Car wont start
  44. which cog size?
  45. URGENT question re Vortech aux pump
  46. Oil Temp Sensor Q
  47. STS Manual Needed!
  48. HKS F-CON SZ Vs Uprev
  49. What would you do?
  50. Random Fuel Return System Question
  51. Dynosty does Boosted Performance Build (PICS)
  52. 350z turbo installation
  53. My Vortech Supercharged 350Z Dyno
  54. What has happened to the FI forum.
  55. FI's Top 50 List
  56. sts hung me out 2 dry
  57. AFR at idle question
  58. Serious question, search yielded nothing...
  59. My ongoing experience with Intense Power
  60. Whp = speed
  61. Is an block rebuild necessary?
  62. Shopping for gauges?
  63. turbonetics turbine pipe diameter
  64. My 350Z TT Experience
  65. ENGINE BUILD for FI
  66. Vancouver Island FI Build... G35 TT
  67. Introducing Dynosty
  68. Engine Build?
  69. Stillen VS Vortech
  70. Exhaust size on FI
  71. FI Question about Race Gas
  72. AFR 15 @ Boost! HELP
  73. Procharger Smooth Idler pulley broke?!
  74. Garrett compressor covers
  75. Ready to buy my setup... Build Thread
  76. Vortech 2.87 Install- blower now louder
  77. jim wolf
  78. no reason to buy a Walbro 255L anymore
  79. HKS TuRBO
  80. HKS turbo kit?
  81. fuel pump wiring help
  82. C/R 8.8:1 or 11:1 with FI application?
  83. help on winter project .. ??
  84. Cosworth + CJ Stage 0 RFS Setup
  85. Finally S/C'ed
  86. Quad charged induction on a VQ35
  87. My build
  88. Bought used CP pistons...how much piston to wall clearance?
  89. huge problem. three cylinders not firing
  90. soo this is what my car sounded like before it doesnt start..
  91. Max power on stock fuel rails converted into a return style system (FRS)
  92. My plans on FI. Got some questions.
  93. The Imported Performance Story so Far...
  94. vortech cog belt
  95. My BP Single Turbo Kit Review
  96. Who said we don't have fun anymore...check this out.
  97. Powerlab gt35 results and issues, PLEASE HELP!
  98. Anyone have a source for APS 3" 4-bolt exhaust gaskets?
  99. G35 Twin Turbo Project
  100. Turbonetics Intake pipe install issues, HELP!
