View Full Version : Forced Induction
  1. K & n air filter
  2. F/I and suspension settings
  3. RC PlugnPlay injector harness clips
  4. FI Build
  5. Camp 2 / odb2 pinout
  6. Have you had any problems with you ROTREX HKS S/C?
  7. Overheating issues...blurping is not working......need help doing test.
  8. Multiple missfire
  9. Ummm...I need some enlightened on a possible screw up.
  10. looking for boost opinions...low budjet.
  11. What happened to the fun we use to have.
  12. Generally, what's more noticable in a DD?
  13. Compression ratio with vortech question??
  14. Can anyone confirm these are Daetchwerk Injectors?
  15. Sleeve or no sleeve..what's the verdict?
  16. Going for inspection.. need help disabling the SC
  17. Building My 06 350Z
  18. Z1 Twin Disc Clutch Assembly Opinions
  19. blowwnn motor? :(
  20. Anticipation...
  21. Max Power on my APS TT and build engine
  22. Eagle H-beam vs Manley H-beam?
  23. Pathfinder VQ35DE vs. 350Z/G35 VQ35DE. The thread to end all threads!
  24. Open WG on a GReddy TT kitt?
  25. Anyone try the Nitto INVOs?
  26. Turbonetics Single Turbo Kit on an 04 350z with 50k+ miles
  27. FINALLY ran a 10 second pass. 10.96@127mph
  28. Enter for pics of the Vortech's nuclear power.
  29. Piping questions
  30. f***ing Tnetics kit issue help needed?
  31. E85
  32. Questions about main studs for my build...
  33. Walbro 255 fuel pump question
  34. 400whp on a rev-up vortech?
  35. HPX alternative??
  36. New build, after a rod nock
  37. flywheel?
  38. Any input to help me build a decent engine?
  39. Any input??
  40. Gettin Haltec ECU manager to recognize
  41. Turbonetics kit AC explosion.
  42. Need advice, opinions etc...
  43. Weird boost problem with vortech and boost limiter valve
  44. greddy tt boost control
  45. Downshift on FI
  46. Is the block out of a pathfinder the same as ours?
  47. Okaaayy...now this is weird!
  48. My Boosted Performance Thread...
  49. Best place to get injectors balanced and cleaned?
  50. HR STS Turbo
  51. VENDORS- piece for me a long block capable of holding 500-550whp.
  52. Can you guys help me locate injector latency info?
  53. Cosworth teams up with Borg Warner on the new EFR Turbocharger
  54. Utec Question / problem *starting cranking and Idle*
  55. Vortech Boost and Timing Table
  56. ECU question
  57. Looks like my engine is dying ( knocking ), but it doesn't seem to be FI related.
  58. Twin Turbo 350z
  59. timing chain question
  60. Built 3.5 Compression test results...
  61. First time @ the track, 1/4 mile runs
  62. Quieting a Vortech?
  63. Vortech SC spitting oil
  64. AFR difference between bank 1 and bank 2
  65. Is there a single dyno proving spacers give power in FI apps?
  66. why not increase boost to reduce trq drop
  67. exhaust question
  68. Oil Pressure Problems TN single turbo kit
  69. UTEC help (STS turbo)
  70. Afr question..
  71. Meatbag's G35
  72. ** New tune, new numbers!! pix and vids! **
  73. Anyone need a set of DSS Pro Axles?
  74. Removing under piston oil spray's and increased oil pressure?
  75. AEM Wideband 02 A/F UEGO Gauge, VQ35HR
  76. Do you guys think my ignition system is weak?
  77. Boost and Stock block = SLOW.
  78. My custom self bleeding coolant swirl system.
  79. Blown OEM Oil Pressure Sensors?
  80. How safe is reving to 7000rpm with a stock cylinder head/valve train????
  81. Installed 928 impeller, larger intercooler, meth solenoid. Now more problems!
  82. Factory oil pressure and temp sensors
  83. My ongoing APT TT smoking problems
  84. New cylinder block, any machining needed?
  85. Hard hot start
  86. F/I advice
  87. Greddy Profec Type S BC? Gain Setting?
  88. Brian Crower 4.15L + APS Extreme Turbo Kit Build
  89. The difference between 450whp and 520whp???
  90. got procharger superchager, i need help
  91. GTM bearing kit for vortech part # and make questions
  92. FI with x pipe?
  93. 07 Hood with Stillen Supercharger on an 06 Rev-up?
  94. Powerlab GT35R Single Turbo Kit Results
  95. Stillen Supercharger for drifting?
  96. stock injectors....
  97. Pro's Vs. Joe's: Forged Performance Battle Royale
  98. Opinions on this tune
  99. Need Suby FI info
  100. Stalling with BOV
