- Cusco or Gready Catch can Install Help!!!!
- Turbonetics Open Atmosphere dump
- greddy TT install part 1: remove engine
- Kudos to Performance Motorsport!!
- where to get higher psi wastegate spirngs for greddy tt
- Installed atmosphere dump, huge problem.... big time overboost. read.
- Anybody running Nismo R-Tune clutch/flywheel w/ F/I?
- TT or SC?
- Tapping stock fuel rails for return line?
- RPM Signal Heed Help fast!
- stillen stage 1
- Greddy TT with Different Intercooler?
- Stock TN kit with upgrades...?Boost spiking?
- Greddy Twin Turbo Fraud Alert!
- 3.12 pulley with 34 tooth jack shaft pulley
- fuel pump
- What power level is least likely to break stuff, once F/I?
- Best Bang for the Buck
- 54K too much for Turbo???
- Driveshaft question.
- 440+ injectors needed?
- difference between AAM and CJM Return fuel kits?
- Sleeves or no sleeves?
- Just some random Dyno Charts..
- TN times, STREET TIRES!
- Whats the current TN ST record?
- Just got MY AAM 3" turbo back W/G dumps
- Emanage Ultimate Help
- Vortech Oil Line Feed
- what is the differnce these two TC
- UTEC / Knocklight / Shiftlight ???
- please help, turbonetics turbo and strut bar.
- Greddy Piggy-Back w/ TN set up....
- utech base maps and turbonetics kit
- Thought I blew my motor today, YOU WILL NOT BELIEVE WHAT THE CULPRET WAS!
- Bad RC 550 injcts!
- Stillen Stg 4 - passing smog??
- timing chain removal
- S/c and Turbo TUNER KITS and my formal welcome to the F/i forums
- AEM wideband logging
- New to SC / Biting Bullet - Vortech!
- TN Revup Updates?
- Performance Engine Software
- Rear wheel bolt....wheel almost came off while driving
- Built Z Motors Machining Process Part II :BALANCING
- exhaust with turbonetics?
- price for aps tt?
- Feedback needed on Blitz gauges
- Haltech interceptor ECU
- Why is there not a turbo kit avaliable for the 06??
- HKS Supercharger and Mods?????
- UTEC with APS?
- Turbonetics running rich at WOT???
- copper o-ringed head gaskets
- EU A/F target using Zeitronix wideband O2 sensor?
- Turbonetics Question?
- FI and traction.
- My greddy tt project story! tuned to 486 hp @9.5
- TN Kit from JEGS.com ...Free shipping?
- Aps Tt
- 3.3 pumpkin...how many use it?
- Piston clearance question fm a non-mechanic
- Finally my ST is being installed!!!
- Does FI beat just getting a faster car?
- Fried? ECU
- TUrbonetics KiT!!!My intercooler pipe to the turbo keeps coming off!!
- Aquamist Water Injection
- TN do you keep VDC on or off
- smoking bad w/tn kit out of exhaust
- 11.98 Turbonetics 1/4 !!!
- Perfect exhaust for FI? I think so! Pics inside!!
- Rod bearings after 20K miles of FI torture. :)
- Intercooler Sprayer with F/I??
- EU help !!
- New TN owner!!!Finally!! 56k!!!!
- high compression and fi
- Octane and FI
- High Flow Intake or CAI with SC
- Poll: JZA80 Supra Turbo V. Built/Boosted Z33
- Is is possible to have a turbonetics kit with no other mod's?
- Quick question need help badly!!!!!!!!!
- Going from Vortech Supercharger > TT
- TT owners be honest with torque feel...
- Has anybody seen April 06's MODIFIED yet???
- Which block to get? AEBS 4.3 , SFR, etc..???
- Built Z Motors: block machining part I
- UniChip Reprogram
- Oil pan spacer ????
- JoeDirt's APS ST v. DynoJet: Part II (with nitrous!)
- Need Help Retuning With Return Fuel System And Emanage
- Engine Strengthening
- 500whp club?
- 06 Build
- whats involve in maintaing a tt?
- Control meth. injection with utec ???
- Is This Even Possible?????
- Calling all PE owners
- Water Temp Gauge
- Which SuperCharger?
- whats everyones f/i and exhaust combo
