View Full Version : Forced Induction
  1. EU issue
  2. Zeitronix power?
  3. Blow Off Valve Poll
  4. Getting FCON or UTEC: reflash back to stock first?
  5. What size injectors to get with my fuel return, Utec's capabilities? help please!!!
  6. Unichip or UTEC??
  7. Torque plates--for those of you who like pictures
  8. G35 Greddy TT Owners - Install Sources
  9. TN Raptor BOV
  10. Vacuum pressure
  11. Calculator for how much timing to be pulled ?
  12. My Pics Of My Blown Block.......
  13. Anyone running higher than stock boost on APS TT?
  14. Bov
  15. my vortech tuner kit install process thread
  16. Which Radiator for FI Z
  17. UR Crank Pulley belt size
  18. what is the AR on the TN kit
  19. Preliminary numbers with HKS FCON...513.6whp & 481tq @16psi
  20. Boost Vaccume
  21. Loudest Spool
  22. Anyone have a Procharger with a Crawford Plenum?
  23. Man alot of motors went these last two months..
  24. HKS TI question
  25. A/C compressor/system failures w/ TURBO INSTALLS???
  26. Turbonetic Dyno 350z At
  27. *** Rob's JWT TT Dyno 6.8 psi / 418 whp!!! ***
  28. JWT twins on my 5AT G by VRT.
  29. Turbos and driving characteristics
  30. PE TT guys??
  31. Quirky bump in Dyno Sheet...
  32. Have you guys seen Zivman's new plates?
  33. Tune safe?
  34. Reading EGT
  35. 700 whp spooling from 2500rpm?
  36. How to make the Z TT (A 3sec car 0 to 60)
  37. Max whp on pump gas! Dyno thread!
  38. I Need A Hook-Up On A Vortech SC...Any Help?
  39. need help: intermittent hesitation @ 5.5k rpm and TAPPING noise on APS TT
  40. Looking for UTEC Map for TN ST and......
  41. Strange occurance?
  42. Beware Of Turbonetics
  43. Turbo utec maps ?
  44. does anyone try to fix fans in the IC for turbontic 350z?
  45. Return Fuel System or Low CR Pistons
  46. Gauges for Forced Induction and what they mean
  47. what should my rpms be at??
  48. Will High HP/TQ bend the Z/G chassis?
  49. Need Help!!
  50. Hole In Block Turbonetics
  51. Callin all TN owners...
  52. How Big is Your Turbo
  53. what does EGT mean?
  54. Vortech and AFR
  55. I love my tuned Z, but it still cuts off around 5-6k rpm???
  56. My new Lungs... PE Cast manifolds.. yay :-\
  57. G35 Profec E01 Owners
  58. Good bye Emanage Ultimate hello HKS FCON
  59. What I need 2 have T88 king..
  60. Just ordered Defi Gauges from JSC Speed
  61. Z with the most horsepower?
  62. Greddy Mushroom of Death replacement
  63. APS TT or JWT TT?!?
  64. CARB catching on, everywhere but China
  65. Serial code for e-manage ultimate
  66. Headlift -- sleeved and non-sleeved engines
  67. TN KIT with different exhaust???
  68. My set up in proces.....
  69. built Z
  70. FI bug
  71. E-Manage U
  72. Which clutch for 600+whp
  73. Fuel hose RECALL
  74. built motor
  75. where to connect boost gauge?
  76. My dyno sheets before and after UTEC.
  77. Which Model to get with my plans....
  78. Procharger Upgrade?
  79. Important question to all tuners and people with lots of knowledge
  80. No Turbo for my Z available??
  81. Tensioner From Timing CHain/TURBONETICS!!
  82. how lean is too lean?
  83. Boost spike after exhaust/pipes install on APS TT
  84. all together there is 443 HP
  85. Fuel return whine?
  86. Turbonetics Over boost mod --Just installed
  87. Finance Turbo set-up?
  88. My car is coming back tonight but MUST READ so this doesnt happen to others!
  89. My Redline VRT 500 RWHP!!
  90. Quick questions about my utec ???
  91. Procharger dyno sheet, need help please
  92. Mod Help
  93. Comparison of Turbo Kits
  94. TN owners what kind of oil are you using?
  95. Veilside Ti with turbonetics kit
  96. 8.5:1 and pauter rods how much boost??
  97. Turbonetcs 1.5????
  98. fried coils, help !
  99. VRT/JWT Quest for 800+ WHP Daily Driver...
  100. The Z develops a 'tick'
