View Full Version : Brakes & Suspension
  1. Big brake kits...so many
  2. Brand New Front Camber Arms! Please Vote!!
  3. Where to get replacement Tein shocks?
  4. Brake pedal does not return to normal position! Help!
  5. Lowering + highering?
  6. Sping rate of KW Variant 3 coilover
  7. Brake swap possible?
  8. rotors
  9. spindle
  10. Help: Lowered my car
  11. TAROX 4-wheel brake system.
  12. Rear Suspension
  13. Shocks labeled with "JR"?
  14. Using a Gtech for suspension tuning?
  15. Somewhere to get 350evo sway bars OTHER than 350evo?
  16. Nagisa Auto Suspension Arms
  17. 350EVO Sway Bar Bushings - Where to get besides 350EVO?
  18. Ground Control?
  19. Facory Alignmet Specs For Rear Camber
  20. Need help: OEM Brembo swap for non brembo brakes
  21. Racing Brake ?????
  22. Just waiting on my HKS Hipermax RS
  23. Hawk hps brake pads for my '04 Z
  24. Stock spring rates
  25. lowering spring benefits?
  26. rotora/stop tech/brembo confused?
  27. 12 Pot Calipers!!
  28. Suspension advice
  29. Springs for a "Club Sport" Daily Driver
  30. Top Secret Brakes???? ( Brembo 8-pot... what rotors???)
  31. TANABE vs TEIN?
  32. lowering??
  33. camber arms and toe arms and toe bolts?
  34. clicking noise when turning...
  35. Need help troubleshooting please...
  36. Arizona Z Car BBK
  37. TANABE Sustec Pro S-0C + Nismo Sways?
  38. Converting from non-brembo to track edition brembo: A couple of questions
  39. Eibach Spring pics???
  40. We got JIC Magic fronts done today...
  41. How Long did your pads last?????
  42. tein basic coilover or eibach which is easier to install
  43. Brembo rotors for Non-Brembo's on eBay??
  44. Megan Racing coilover review
  45. Installation Price Check
  46. TC Kline/ KONI shocks and Espelir Active GT Springs?
  47. Changing brake pads...
  48. Springs or Coilovers
  49. Can some one scan me their JIC Magic Coilover instructions?
  50. G35driver.com Poll: SPC Adjustable Front A-Arms for under $400
  51. Lowering springs affect stock shocks
  52. Hotchkis TVS
  53. How much time for a shop to install new springs?
  54. Tire Feathering and Aftermarket springs
  55. Check out these Camber Arms. Do i need toe bolts?
  56. Finally installed- Tokico D-spec.
  57. Cusco/SPC Setup
  58. Cost of Hotchkis springs
  59. anyone using Rotora with Hawk pad?
  60. Endless CC-X Brake Pad Impressions
  61. Okay, I'm fat. Should I set the driver's side stiffer?
  62. All you guys with Tein Flex
  63. "how to" link to replace Rotors???
  64. Swaybar Questions
  65. Questions for Tein Basic users
  66. Spring Rate Database?
  67. How often do you change your brake pads on your Z
  68. SPC camber/toe kit
  69. Tein Basics or something else??
  70. Questions about STOPTECH install...
  71. Suspension components: sprung or unsprung weight?
  72. Any lowering spring comparable to the NISMO Suspension Spring?
  73. OEM Brembo Upgrade
  74. Rear camber arm / toe bolt question. Pics included.
  75. question about coilover for the expert
  76. Will JIC Magic FLT-A2 Coilovers fit on G35 sedan?
  77. stupid break question
  78. Need to find Camber Arm installation instructions.
  79. Brakes screech at only 6k..
  80. STOP TECH - 350Z / G35 Stage 2 Brake Upgrade
  81. Spring/Coilcover question
  82. Best spring and shock combo? Tein?
  83. What size nut for swaybar end links???
  84. Brembo Sport Disc Upgrade for Non-Track Z
  85. How do I take off front Coilovers?
  86. How do you adjust Tokico shocks in the rear?
  87. S60R Rotors...
  88. i've never bled brakes before
  89. 350Z rear rotors
  90. Upgrade? Yes, now what to choose...
  91. Advice on next suspension upgrade
  92. Tokico Shocks and Springs set
  93. Hawk Ceramic pads
  94. brakes sparking?
  95. how well do axis ultimate Brake pads hold up on the track?
  96. Inexpensive Brake Upgrade?
  97. Hawk HPS Pads for cheap?
  98. Brake pad shim and shim cover replacement
  99. Brake dust on front wheels
  100. Edfc Help
