- MRC Motorsports and 1000whp+ tuning....
- MRC Motorsports tune Mike from Long Islands APS TT..
- MRC and another Great tune, Turbonetics single.
- need haltech map
- ECU Reflash???
- COBB AP and JWT PopCharger + More
- Vortech/GReddy Emanage/Nismo cams = can this be tuned to run well?
- What stand-alone ECUs can be used?
- Church Automotive/Osiris
- UTEC Timing Map for Vortech
- utec issues with battery hookup
- JAW: Just Another Wideband
- If I reset the ECU??
- Stand Alone ECU
- Target AFR's for a Stock Block (APS TT)
- best way to mount utec?
- any one can help
- Help with this map
- injectors and Utec
- Can I upload a map to UTEC outside of car?
- Turboxs Tuner Help...
- SAFC S-afc A/F ratios tunning question
- HELP!! Which wire do it hook Narrow band gauge to?
- ECM Reflash Results by TechnoSquare
- Was told to create a new thread. Why ECU reflash versus...
- Reflash / Dyno Tune
- Reflash????
- Newb Question about Utec and WB
- osiris or cobb ap?
- need some utec help (logs inside)
- Vortech + UTEC runs rich in partial thottle??
- Jetchip.com?
- Tach output on Dynojet?
- car not idling w/ utec
- Totally Disappointed.
- Affecting of Octane Rating and Additives on Tune
- Reflash Cost
- Any Dual Safc usage on the HR?
- Old map with a new setup?
- TB mod= worse performance???
- Utec fuel map interpolation
- Help...WHY
- COBB AccessPort is out!!
- ECU reflash and HFC related question
- connecting to utec issues
- Haltech vs other piggybacks
- ECU addition, Tri-phase version. Any reviews?
- Haltech Update
- UPREV's CIPHER program
- Haltech and Shift Knock
- Base Flash 08 350Z NISMO
- ECU reset?
- What do you all think of the COBBTUNING Access Port???
- Dyno runs bad for the car?
- utec guru.
- anyone dyno'd a 2006 350z automatic baseline?
- Best ECU upgrade?
- autosportwiring harness need help
- Aftermarket Enginemanagment debate.
- 06z VS 335i
- Pulsar spark plugs 10hp 7tq?
- reflash in orlando area?
- FCON Harness - Black Box
- COBB tuning AccessPort?
- AEM ems anyone?
- Haltech Tuning: Can't Get a Stable Idle!!!!!!
- Size of Spearco intercooler
- so i got the cams in....been dynoed untuned
- unichip and standard ems blow after 1 bar
- Can I tune out my boost creep?
- UTEC strange effect
- Looking for a UTEC base map - TN kit 650cc injectors
- Need own help w/ choosing the right reflash
- E-manage Ultimate Installation Help
- tuning the z with full bolt ons
- Emanage harness
- Cable That Goes From EU --> Laptop
- Tuner Reg and EGT Input
- Coolant control valve ?
- Questions about utec
- MAF voltage vs. Air Flow rate data anyone?
- Utech on a stock car.
- APS Tall Boy
- 2 sec dyno queston???????
- Emanage Ultimate VQ35HR
- Haltech Wiring, for Boost Solenoid and External MAP
- calling out all HKS TWIN POWER owners!!!
- haltech platinum question
- Software
- Zeitronix 02 Sensor goin crazy??
- Megasquirt?
- Utec and APS Extreme Fuel System?
- Haltec tuning Set up questions
- UTEC tuners
- Tuning a utec
- U-TECH, Bolt on's and Meth.......
- Haltech Tuning Help!!
- UTEC N/A, throws CEL, VDC and slip lights, JDM Z
- Wideband. Which Bank?
- Please read. no go plus engine code
