- Microtech for 350z???
- Check out the new HKS CAMP2
- Dyno Day in Arizona? - Custom Tune by Church Auto with OSIRIS!!!
- Factory ECU tuning
- TurboXS (newbie Q's)
- haltech Timing maps
- tuner pro help
- avoid shop in j-ville
- Acronyms.......what is NA?
- emanage removal?
- 03 Innovate Wideband Setup Questions
- utec question
- UTEC Tuning (Dyno Jet vs Dyno Dynamics)
- Factory Flashes
- AAM tune over 1 year old
- can utec change rev limiter?
- utec and technosquare?
- What other units if any...
- Vortech Tuning (bad Split Sec Box)
- utec questions
- 03 rpm signal wire?
- NA tuning video comparison
- Dyno Sticky?
- nonrevup question...is it possible to get more power topend?
- Is there a FUEL PRESSURE sensor reading on our OBDII?
- utec controlling boost
- New Haltech and PF Dyno Tune
- Tuner for 04 Models
- VQ35DE Twin Turbo Tuning Tips
- ecu layout schematic
- Anyone using TurboXS Tuner without UTEC?
- Has anyone re-dynoed weeks after dyno + tune?
- Knock & timing retard at high RPM (Vortech)
- GReddy turbo install, now no start
- Cobb Tuning AccessPORT beta testing
- Good Tuners in Central Florida?
- UTEC (newb) question
- Best Ems Hands Down.
- Logging with AEM UEGO without a serial cable...
- autosport 350z g35 harness $100 is this a good deal
- Does anyone know of a shop in NW IN or Chicago that can install Greddy E manage
- What EMS is best for me????
- Timing problem, exhaust manifolds turning cherry red
- looking to tune my ecu, what are your best numbers?
- unichip vs. Utec ??????????
- aam flash send it or drive there
- VQHR ECU on 07 base completed.
- Greddy V-Manage. do they make it for the rev up.
- any tools that can datalog??
- Is it worth it?
- Initial Numbers in on Technosquare Flash for the HR
- EFI University!
- anyone tried Blitz RVIT Color
- Haltech Tuning
- 2007 z engine management
- jacksonville tuners?
- Is anyone using Data Log Lab?
- charged twice...reassure me...
- Utec vs Technosquare Reflash
- getting the car tuned
- Anyone with similar NA mods tune with UTEC?
- Just came from the dyno. Interesting day to say the least!
- question RE: flash tuner
- Car wont go past 4k rpms???
- AAM- Custom ECU reflash
- Ohio Tuner?
- TXS Tuner won't record RPM ?
- TXS Tuner Install (So you can see the AFR Readout)
- Does Osiris Work with Built Motor and Turbo?
- utec tuner near santa barbara, CA?
- UTEC & Wideband
- dyno numbers(does this sound right?)
- 380 injectors on stock ecu?
- UTI Data Logger
- A/F Help Have Cipher Log
- UTEC-Tuned STS - Leaning Out to 21 AFR on Low MAP!!!
- DashDaq
- UpRev Reflash
- Car Tuning and Reseting ECU
- Callin out Injected Performance...
- anyone using the "Boost Map 5> Spare Solenoid" feature of the UTEC?
- Anyone use UTI logger?
- i neeed a tuner in ny
- Turbo XS BCS install: boost map needed
- Where is the ECU LOCATED???
- Looking for tuner in kern county..
- CEL misfire 1 and 2
- R4 software needed
- im finally switching...
- Utec All Of Sudden Run LEAN.
- Target A/F when Tuning Forced Induction?
- vortech base map?
- What's up with Technosquare?
- Innovate Motorsports Standalone Wideband Gauge Kit??? what does this do?
- E-Manage Blue questions
- UTEC Temperature compensation
- sorry moved
- SGP tune
- Hows my tune? Please comment on my Maps.
- At what point do you need a tune?
