View Full Version : Tuning
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 [13] 14 15 16 17 18 19 20 21 22
  1. Delete
  2. Anyone have info. on the HKS F-con IS?
  3. AFR looks weird
  4. I just dynoed my car with Osiris. Something strange is going on.
  5. Tuning options for '07 HR
  6. I need V2.6 of the UTEC software to control spare solenoid
  7. I just got Osiris. Now I have some questions.
  8. swapping ecu's?
  9. apexi neo for 07 Z
  10. How true is this?
  11. UTEC Re-Tuned by MRC
  12. New TurboXS UTEC - Coming to the 350Z?
  13. Would like some input?
  14. Injector deadtime
  15. Removing Utec?
  16. amateur tuning question
  17. tuned my z on utec with a ses code....questions, please help!! :)
  18. ECU controll box...Would this thing actually work??
  19. UTEC where to get installed/tuned in SoCal?
  20. Na/ dyno dynamics/ utec tuned
  21. Utec Knock on ECU just below 0 PSI.
  22. HELP Utec
  23. E-Manage Blue "special" cable
  24. performance box
  25. Installing UTEC and MAP sensor tonight
  26. Does anyone w/F.I. run the Haltech?
  27. Where is it?
  28. UTEC Where to buy?
  29. Stroker Kits for N/A application.
  30. utec shift knock fix
  31. utec, quick question
  32. Split Second box ?
  33. Tuning without engine management
  34. shift knock with utec WTF
  35. Fake Emanage?
  36. diffrence in 4th and 5th gear pulls
  37. utec base map
  38. tuning with greddy e manage
  39. Mating a piggyback with a TS ECU
  40. UTEC: can it datalog coolant temperature?
  41. Utec USB Driver
  42. UTEC & Dead Battery
  43. 03 Mustang Dyno with some mods
  44. Technosquare reflash question / issue...
  45. Additional info about the E-manage Blue please
  46. Any more power to squeeze out of stock motor with tune?
  47. How to install...
  48. ECU question
  49. Hydra Nemesis anyone?
  50. houston unichip tuner
  51. Recommendations for HP gains and cooling upgrades
  52. UTEC air temp compensation spreadsheet
  53. Idle Speed Increase
  54. OBD II Sony PSP
  55. power gains from tuning on n/a
  56. need help with rough idle/running lean
  57. Utec On Map
  58. UTEC load points
  59. greddy e-manage ultimate or u-tech
  60. RC 650cc and Fuel pressure?
  61. Dyno results with Osris, and exhaust cams unplugged on a revup.
  62. Utec install cost?
  63. How to subtract Timing with Utec?
  64. Engine Stress
  65. Scaling Big injectors with UTEC
  66. G35 ECU Terminal for Engine speed?
  67. G35 On the Dyno Solution to the Rev Limiter at 5300-5500 RPM Florida
  68. UTEC base map for Vortech, 3.12, 440 injectors?
  69. Knock sensor installation
  70. Anyone have to replace their alternator?
  71. My first UTEC log...any suggestions?
  72. How to install utec on g35
  73. Tuning Help
  74. New Tune (Sharif) w/ Evott Exhaust and UR pulleys
  75. Any interest in "Staged" level REFlashes?
  76. Cant boost in 1st gear! Heres my logs:
  77. UTEC: Why does it say stock mode?!
  78. Can you flash the UTEC via the USB port on the UTEC?
  79. Anyone have a UTECtiming map for an NA Z
  80. HKS EVC question....
  81. UTEC + aftermarket wideband o2 sensor
  82. How to connect AEM Uego to computer.
  83. CEL-Throttle position sensor code w/ UTEC??
  84. Tuner UTEC problem
  85. A/F & UTEC Problem
  86. Mac tuning software
  87. From SS Box to Utec...
  88. Where can I get an R4 software from?
  89. MPS_UTECLogger V3.0
  90. VERY URGENT Emanage Ultimate Problem (2-step)
  91. ECU Noob In need of advise!
  92. R4 software
  93. apexi "neo" sufficient for bolt-on tuning? is u-tec overkill?
  94. Any One Using UTEC CLBC (Close Loop Boost Control)
  95. A/F tuning ?
  96. ecu flash
  97. what to buy
  98. UTEC installation question: Molex?
  99. need help with utec
  100. Utec + 440cc injectors, help with map
