- A quick question on different rear gears
- Help installing TXS Tuner kit
- Finally, a good dyno session, and a tune.
- Will an EMS help ME?
- AEM Fuel / Ignition Controller (F/IC)
- Engine management for HR motors??
- How much does a tune normally cost?
- Strange UTEC problem. Map Sensor?
- Turbo'd without a Tuner?
- Having problems with the utec
- knock sensor type and info
- Autometer nexus oil temp help
- UTEC update problems, any advice?
- Tuning in Minnesota
- Patch harness question. Very early ecu versions
- Recommendation for another reflash
- Unichip plus 10 RON Octane Booster - timing?
- unichip tuners in tx
- logging on a pda
- Osiris vs UTEC, my experince.
- Does the UTEC come with the Map sensor?
- Utec Decisions and questions....
- Emanage help simple question
- To all you tuning gods
- was my computer already tuned?????
- Tuning?
- UTEC Tuners
- what should i do ??
- Having trouble uploading map to UTEC from PC
- Cobb Access Port... Any updates??
- Greddy 440cc UTEC Base Map?
- Need help wit A/F issue
- need help w/ unichip
- Knock Logs
- AEM piggyback
- greddy Emanagement/UTEC/Apexi A/F controller bahhh help me
- UTECH or AAM ECU Reflash?
- expected dyno numbers....
- Logging AFR and RPMs with Innovate or other?
- Afr 17.5 +
- Soft Rev Limit on UTEC
- Tuner for the MAF???????
- Air Temp & Humidity: Effects on performance
- Some issues with my UTEC
- UTEC tune problems
- New Dyno Run!!! and question??
- Stock ECU w/Stillen Piggy Back
- AMS tuning 350z's??
- UTEC tune dyno #'s
- Tuning UTEC without MAP sensor
- N2O + Nismo Cams = What tune?
- Bad WB Sensor on Tuna
- A/F confussion ???
- Greddy Emanage/EO1 primer
- Rev up owners w/utecs please help !
- what is the best
- Beginner with utec???
- Can I trade my ECU with another 350z owner?
- Anybody swap UTEC for E-Manage or viseversa
- Ignition Amplifier need?
- dont know what I am looking for help!
- noob question
- UTEC boost control solenoid VS aftermarket boost controllers
- Wiring Installation AEM Wideband
- Differances of vq motors.
- Gauge Question
- running too rich?
- To tune or not to tune? that is the question.
- Anyone using HKS AFR?
- My Dyno Sheet! Questions
- When is a good time.
- R4 software timming settings with 3.12 Vortech Pulley
- I got TS reflash! I have questions too
- tune with Camshafts
- Dyno results
- Undecided on reflash; help me out. Do I really need a tune?
- Utec users/Please chime in!
- Osiris from Uprev
- dyno 17.5 A/F Ratio!!!!
- VDC off / SLIP / Check Engine Light with UTEC
- Maximum power with stock MAF/fuel system
- Greddy Emanage Ultimate Base Map for TT
- widwband sensor location
- Knock on shifting!
- boost hitting sooner...do I need a new Utec map?
- HELP Need a base tune for Utec 550 and sd
- Tune a stock Z for more performance?
- UTEC Closed loop boost controller
- Resetting Idle Question.
- Greddy Emanage Tune Help
- To Lean???
- Cheap way to see long/short fuel trim?
- UTEC Timing does really weird things
- I need another N/A tune bad....06 revup
- UTEC Open Loop Enable
- I Finally Got My Car Dynoed
- Mrev/Uprev Results
- Jdm 350z + Utec ??
- ECU reflash
- Meth/Water Injection
