- Emanage ultimate or UTEC
- Need help with physical install of UTEC
- Emanage Blue / Apexi Neo question
- Power steering
- F/I without a tune
- Scared to Death of my UTEC!!
- Going in for TS reflash on 02/19/07
- Dynoed 267.7hp - 254.3tq
- ECU location?
- Efi101
- Ordered UTEC and need some AFR suggestions (calling Wired24/7)
- When to tune with the small mods?
- Greddy V Manage
- AAM Flash – dyno, pics & vid!
- Updating UTEC to 2.8d ?
- Will I be ok
- FCon Vpro ?
- Autosport patch harness for 06?
- emanage blue controlling timing
- o2 sensor voltage..datalog question
- Another great tune by Sharif!!
- E-Manage Ultimate addon question
- Ecu Reflash
- Hydra EMU next week ?
- UTEC ThrottleControl.mot file
- UTEC Boost control
- UpRev Review and Tune
- Bee*R drive by wire system
- Vortech@9psi with stock internals=490WHP
- Cipher Vs AutoEnginuity OBD-II Scan Tool
- easiest way to know the duty cycle of the injectors?
- Weird issue...
- Utec Map Needed for Break-in??
- APEX-i SAFC NEO
- Utec Delta Arrives !!
- UTEC First Start Rough Idle and Solution
- ECM Problems with TH400?
- where to install the HKS turbo timer ???
- Hydra ems
- Magnetti Marelli Engine Management Info.
- My Utec Tune! Thanks To Jeremy (audible Mayhem)
- GReddy V-manage (Variable Valve Timing Controler)
- UTEC - Boost Issues
- '05-'06 ECU in a '03?
- What tuner do you use?
- Apex'i SAFC tuning
- dyno
- Tach signal for dyno.
- UTEC new to Hawaii Tuner
- What happens when you reflash your ECU for larger injectors, then go back to stock...
- emanage ultimate??
- Tuning Utec for a Vortech
- Utec and Windows software ?
- technosquare ecu waste of $$$?
- Air/Fuel Sensor install help! TurboXS Tuner
- utec and check engine light
- ECU for NA
- Tuning ??'s AAM/UTEC/TN ST
- for those w/ rev up & unichip
- AccessPort or UTEC????
- Raising the rev limit
- EU installed on VQ35DET, need base map? please.
- EU installed on VQ35DET, need base map please
- Unichip plug n' play worth it
- Cipher: Analyzing A/F and Timing thru 2nd & 3rd Gear
- dead battery effect on UTEC
- Tuners in Texas
- Neen help with e-manage
- Hand Held Tuner ?
- Not sure, but I think I have ECU Reflash
- Technosquare vs AAM ????
- Greddy UTEC Base Map?
- My first FI log. Help me out guys.
- Whats The Best For Fi?
- UTEC/ECU; Having Trouble Installing Unit
- Resetting ECU?
- Vortech @ 7psi, how lean can i go?
- Car won't start when engine is warm.
- slightly mooded NA Z.... greddy e manage blue..
- Discussion on the PiggyBacks! NO 56K
- Where in NJ can I get my Tack model tunned?
- which year track model is best?
- Haltech Interceptor for the 350Z!!
- apexi neo
- Do i need to reflash yet?
- Speed Limiter Removal
- Where and How much did your UTEC tuning cost you
- Tuning Books (I searched)
- Map switch #1, but my dashboard reads 0. Correct?
- My Remote Map Switch / Utec install..
- lcd engine management
- Tuner needed
- Advice on ECU reflash/S-AFC2
- what laptop do you use for your UTEC?
- how much HP is gained with timing advance (NA)
- 300zx motor swap
- ECU flashing and Editing Software
- Aam Flash Issue???
- 350Z Engine Software
- aem uego gauge install?
