- OEM wideband adapter for Dynojet wideband plug
- Timing question
- Haltech Aux Rev Limit Issue; ideas??
- Is a tune worth it...
- R/T Tuning, Uprev Osiris, and the Nissan GTR
- just got Osiris tune
- haltech training seminar
- Have any user from 350Z HR Technosquare?
- My Uprev tune with basic bolt ons...
- UpRev Question!!
- AEM Series 2 Product Review for RB Engines
- Looking for a tuning shop close to New York
- Where to tune??? SoCal
- Fuel Economy?
- Going back to stock but I have a tune?
- Reflash to stock?
- Just got UpRev... WOW!
- Enthalpy!
- osiris question
- Zeitronix Zt-2 Install Plus Utec EMS
- Uprev tune at Performance Motorsport (pics)
- Where do I find the Vehicle's ECU Part Number??
- Pop charger only 06 dyno
- SoCal Tune
- Quaife or UpRev + ART Pipes? Which would you do?
- dual display wideband gauge
- Osiris Tune on OC motor
- Motor Stumble "loop"
- Do I need a re-tune?..
- HKS Fcon S not connecting after firmware update?
- tuning at idle problems (aps 880cc with haltech)
- Haltech: APP vs TPS
- 2JZ-GTE best way tuning
- UTEC users/ tuners questions
- Tuning??
- Tuning??
- Osiris reflash results with bolt on
- UpRev new user..
- 2006 350z osiris tune results
- Has anyone heard of this with up-rev???
- Need Osiris ROM files
- Reflashing stock ecu or tuning with a plug and play
- buying a tuner
- Looking for a tuner/dyno near rapidcity southdakota
- Wanted: UpRev Tuning DIY - Tuning 101?
- Engine Grounding Kit, worth it? or Mostly Cosmetic?
- UpRev Tuner and 2004.5
- St. louis Mo. Speed & Sound tuning
- upper vs lower o2 sensors vs tuning
- Looking for a tuner/shop in the midwest
- new nissan ecu update software?
- Possible to modify tuned ROM to work on another 350Z?
- South Florida Shops?
- Uprev injector latency -- not how it used to be?
- More uprev questions.. license and reflash
- help needed on ecu
- cobb maps
- Got tuned today!
- Osiris -- fuel schedule scaler, where are you?
- fuel pump question?
- ECU Flash????
- trip to forged
- Hitting Rev limiter???
- Osiris 'Knock Strength' massively negative at WOT?
- engine managemnet for HR ?
- Cipher log visual graphing tool (or any .csv file)
- Intermittent RPM signal haltech
- Haltech rev limiter - fuel vs spark
- Aftermarket clutch kit like oem
- Looking for tuner close to NW Pa???
- Can anyone tell me what Data Byte means uprev
- base map for Hydra
- Uprev Osiris Flash question
- JET V-Force/PCU advice
- A/F signal output from UTEC
- Which EMS to run
- uTec reset by stock ecu?
- NATS disable via Uprev
- new Uprev log analysis tool
- Technosquare is no longer offering ECU reflashes...
- UTEC tuners in Sacramento
- advice with Technosquare Reflash
- Newb question about uprev
- uprev cranking enrichment
- Unichip????
- COBB Lean Spike
- Cobb question
- Need a Haltech Base map
- Wire harness help! Car wont start...
- can a utec lose its maps?
- utec temp compensations
- My Osiris has 4 Licenses. Does that mean I can use it on 4 cars?
- Dyno choices for tuning purposes
- haltech: cold and hot start issues
- Uprev Osiris Tuner With base model question
- Buying an used Osiris Tuner Version?
- Utec hr
- Had my APS TT tuned. Torque seems low to me. What do you think?
- Osiris Reflash After a Disconnected Battery
- ECU Chip
