View Full Version : Tuning
Pages : 1 2 3 4 5 6 [7] 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22
  1. ECU pulling timing, tuned with EMU...
  2. Working on my N/A project. Which EMS is best?
  3. utec
  4. Innovative LC-1 connection issues
  5. drilled throttle body plate+utec
  6. Uprev tune...high flow cats first???
  7. Mods: When to tune
  8. COBB...another one gone
  9. Osiris Cranking Fuel Enrichment
  10. raising idle via timing
  11. just bought a z.. and i dont know what this is.. help?
  12. Too much ECU?
  13. How does Map switching work?
  14. Hot start tuning with the Haltech
  15. Osiris E tune vs Pro tune?
  16. utec vs Hks Fcon IS
  17. Osiris suggested base maps?
  18. Haltech issues
  19. Install Cruise Control Switch for Osiris
  20. Can I sell Osiris?
  21. where to tune
  22. For those getting rid of your UTEC
  23. Knoob question about tuning...
  24. wide band for tuning
  25. 2004 VQ harness pinout?
  26. Sound Performance Review :: STS Turbo and UpRev Tuning!
  27. Emanage Blue base map
  28. hal, any haltech updates available?
  29. Stay with Utec or go with the Uprev
  30. PCD Performance Chip Stage 1
  31. Open to suggestions
  32. Osiris Air/Fuel Blip
  33. Unichip - what gains can you get?
  34. 03 touring dynoed, hows my afr?
  35. need help UTEC vs Cobb accessPORT
  36. utec help
  37. Osiris CVTC vq35de
  38. UTEC transition
  39. Help!!! Lean issue???!!!???
  40. CJM Fuel Pressure
  41. Need help with POS Innovate LC-1...
  42. What type of DB9 cable is needed for tuner>utec connection?
  43. are thouse numbers normal ?? so disappointed
  44. Osiris
  45. Cobb Accessport
  46. pleas help
  47. UTEC Versions anyone have 2.6 C??
  48. cobb tuning access port
  49. GTM or technosquare reflash
  50. No one uses Megasquirt?
  51. 03 Osiris Tune Results
  52. Map for Greddy ultimate needed desperately
  53. Map for greddy ultimate needed dispertly
  54. UTEC lean under moderate load
  55. Utec MAP threshold for open loop
  56. UTEC in cold weather
  57. Utec help!!
  58. Getting the most out of a fairly stock motor.
  59. HKS FCON V Pro fuse
  60. COBB Tuning the HR
  61. Has anyone gotten Haltech to send Voltage to MAF?
  62. Best base map to get utec to a tuner
  63. ECU Tuning
  64. Tuner in Washington
  65. What Time Units Does Cipher Measure In?
  66. ECM info??
  67. N/a afr
  68. cobb tuning vs. osiris tuning
  69. Injected Performance Reflash
  70. Getting Tuned :hehehe:
  71. need help please
  72. Slowboy Racing
  73. ECU
  74. Would u do a "tune" when u installed your JWT Popcharger / CAI?
  75. Bought Netbook for Tuning
  76. So.. UTEC software ever going to be updated?
  77. Utec Pro's Chime In!Help Needed!!
  78. Looking for a shop in Houston
  79. Aam tune??
  80. Wastegate Flutter with HKS EVC 6
  81. UTEC tuner
  82. Cobb tuning problem.
  83. 2000 rpm idle
  84. engine "errors"
  85. Silly question, but I have to ask ... (UTEC)
  86. Vortech tuning - what would be the best approach?
  87. Best Reflash for simple bolt on's
  88. What is the best map for Vortech on a Utec
  89. Help Plz!! Utec or Unichip?
  90. Utec problem
  91. What rev limiter do you all run?
  92. Possible answer to TurboXS Turner WB DISPLAY Option.
  93. What would cause I utec to read lower to acutal PSI
  94. OSIRIS Final Numbers, HB SPEED,SOCAL
  95. Cobb Tuning Access port
  96. AEM fuel/ign controller install
  97. Installed Greddy Emanage Ultimate on G35C A/T Need Help Tuning for N/A
  98. Please help about Tuning
  99. Anyone know ow to tune NA utec with 600cc injectors
  100. Custom Grounding Kit....installed
