View Full Version : Tuning
Pages : 1 2 3 4 5 6 7 8 [9] 10 11 12 13 14 15 16 17 18 19 20 21 22
  1. Please delete me.
  2. How to make logs with Cipher on Dyno?
  3. technosquare reflash questions (vs Osirus?)
  4. Help Autronics yes ABS no
  5. Power Programmer Help
  6. Post your Logs
  7. Utec using Speed Density Question...
  8. USING UTEC i have CEL, VDC and slip lights all on at the same time some times..
  9. COBB Tuning AccessPORT released for the HR 350Z's
  10. haltech cuts out the engine under WOT
  11. Does ECU Listen to Knock above 5000rpm?
  12. greddy e-manage?? utec???
  13. map 0 and knock
  14. utec and SSV
  15. Utec Rotary ?
  16. 350z Programmer help
  17. TurboXS Tuner (Tuna) Install Questions
  18. Utec Maps
  19. Just Had ECU Reflashed Again For Cams
  20. AEM Wideband and UTEC
  21. How's your tune holding up?
  22. hks v pro
  23. wanted: vortech boost logs
  24. ECU upgrade.....
  25. Boost controller needed?
  26. vq35hr apexi afc neo w/ cold air intakes & exhaust
  27. Most power from a UTEC
  28. Haltech 350Z Platinum Dyno results
  29. ems dilema. need some help!
  30. Flash to lower speed governor?
  31. chips for 2008 350z???
  32. Cipher Logging Question
  33. Osiris Tuner now available!
  34. Tuning Idle on Cam'd Motor
  35. Turbo XS utec basemap 600 c.c. injector
  36. motor swaps without ecu
  37. AFR Discrepancy Dynojet Tuning vs. On the Street
  38. Question about switching CAI's after Tune
  39. tune up?
  40. How do you know how much to tune the timing?
  41. Dyno on Tiptronic
  42. UTEC Doing something weird????
  43. back from dyno graph/video
  44. How to deCipher injector duty cycle?
  45. Software for Stock ECU logging
  46. Ecu
  47. A bit of help needed: routing a vacuum line
  48. Osiris 2.0 for previous customers. (free upgrade)
  49. Some advice please
  50. Tuning For Fi
  51. will a utec help
  52. Will my tune be erased if I dissconnect the battery
  53. What aspects of throttle can Osiris control?
  54. Ecu + stock
  55. Vortech tuner kit + Utec + cool weather = lean a/f
  56. Haltech and LC-1... AFRs reading 18-20 at idle
  57. ecu reflash + dyno tune
  58. For everyone against the SAFC2
  59. Fmu
  60. UTEC running rich need help asap
  61. apexi safc
  62. Standalones EMS for 04 350z ?
  63. Tuning Classes
  64. emange blue or others?
  65. stock 350z with greddy e-manage
  66. Cobb Accessport for 07
  67. Interesting read on tuning (excerpts by Shiv - not for Z/G but still good stuff)
  68. What settings to use on Cipher for a TEST RUN
  69. Haltech Questions
  70. My experience with Cobb Accessport so far...
  71. Anyone using a Mac to data log or access the Utec?
  72. Someone look @ this UTEC log?
  73. Anyone with experience hooking up haltech?
  74. AccessPORT Beta testing for HR motors. Looking for people.
  75. UTEC / Hyperterminal driver HELP!
  76. Houston Area
  77. Utec Parameter Settings??
  78. Group buys for Cipher ?
  79. Blitz Throttle Controller Installed!
  80. Quick question for the tuning guys.
  81. High Elevation & UTEC Owners...
  82. E 85 vs Meth Injection
  83. Looking for some HELP
  84. Haltech Software for Windows Mobile 6.1 or later
  85. Uprev wants suggestions.
  86. Gizzmo Launch Control
  87. **engine Management Systems**
  88. With these mods will I need my ECU reflashed??
  89. Is it possible to hook up a F con to a 7" screen
  90. Perfect N/A Air/Fuel
  91. First impressions of the ProEFI
  92. UTEC on N/A, worth it?
  93. i don`t know any thing about tune,help??
  94. Help! Innovate LC-1 AFR problem
  95. Opinions of GRD Chicago Tuning Vortech 2.87 with Utec
  96. Understanding how to dyno-tune aftermarket ems
  97. noob question, pls help
  98. Did Some UTEC Logging - Mind Taking a Look?
  99. Upgrades Finally IN!! Some Q's
  100. UPREV wait time?
