- My 07 on the dyno (video)
- Stillen Headers (for the HR)
- Oil pressure indicator question
- 380rs
- Oil cooler suggest
- Samco Sport hoses - almost here!
- WTB: Intakes and plenum of the 380RS competition
- Piggy back options for the HR
- Worn engine bearing warrant full motor replacement?!?
- weird clutch sound
- anyone swap out the ring and pinion gears in their Z?
- RPI Intake Scoops
- nismo catback exhaust
- stillen duel intake problem
- VQ35HR price
- Trouble finding HR brake pads
- HR in need of plenum spacer?
- test pipes = too lean?
- Birthday ideas for my car :D
- VG35HR Engine F/I question, not the usual one. just look.
- 07 HR - AAM Test Pipes - Dyno / Vids
- Wierd Idle
- Need advise for my 07
- HR Aero Products!!!
- 2007 Z Fi............
- Link to JWT Clutch Kit Sale
- Mil Eliminators
- Berk HFC hissing?
- Is this normal?
- downshifted into a wrong gear!!!!!!!! (in my HR)
- My Stock 07 dyno/strip weekend(vids)
- VQ35HR´s oil consumption
- HR mods-can someone give me advice?
- supercharger kit for HR
- Dynorun Austrian MY2007
- HR engine oil filter
- 2007 350z Cold Air Intake Prototype!
- what fluids required when changing Ring & Pinion
- 07 HR vs. 06 Revup - same dyno, same day
- Clutch/tranny
- too noisy
- Dynoing VQ35HR question...what gear?
- Best Motoring vid of vq35hr 350z
- HI Flow Cats by Stillen and Random Tech.
- ABS problem after installing VLSD into my base Z
- Dyno #'s
- So im about to order Amsoil
- How many different size shims are there for a new set of gears?
- Greddy TT
- COBB Tuning Blog....Nismo, Fujita intakes tested on a G37
- Top Speed Exhaust Fitment Q
- HPS Intake Test Fit for 07-08 350Z (SoCal Area)
- Cam Lift/Duration
- what speed/rpm gives the BEST gas mileage?
- Best performance mod for the money...
- Lightweight Flywheel
- Nismo cold air intakes
- AAM Test Pipes installed (HR). Vids/pics coming
- 07 Test Pipe install - question
- 07+ Brake pads
- Recall + Shifter guide = problems
- dynoed today!!! on spray very suprising
- GTM VQ35HR Camshafts
- my clutch got stuck like half way while i was reving up, can someone explain?
- How hard is it to replace an engine?
- need some help??
- Greddy TT Kit in ImportTuner
- VQ35HR aftermarket cams???
- Creak and crack noise?
- Some theoretical calculations for HR intakes.
- Flywheel rattle?
- i want f****in headers!!!!
- AAM Test Pipes Installed**vids**pics**
- Do Titek test pipes fit on a 2007 350Z?
- VQ35DE vs VQ35HR
- Dyno: Stock then with Greddy EvoTT
- After Market Slave Cylinder?
- Slave Cylinder Question
- aam test pipes finally install write up
- Help with Slave Cylinder Problem!!
- Install *JWT Pop Chargers* pics and review
- fix fixed slave cylinder?
- any good dyno shops in San Antonio?
- Serpentine Belt Owned!
- 100 shot
- DYNOED- VQ35HR - 12HP 27FTTQ GAIN - Bassani Exhaust
- Stillen Dual Hi-Flow Intake Polished Long Tube Version
- Nismo clutch/flywheel?
- Wow. Got the recall work done.
- Wierd noise after slave cyl recall
- Another Test Pipe Thread
- Oil Catch Can
- Slave Cyl recall
- Stillen HFCs (HR)
- haha moron on another forum...
- 07 350Z and 08 G37 same dyno same day
- aam tp's with greddy tt TD or aam 3" TD?
- Reputable Z Engine Builder
- Just got back from getting my Slave Cylinder swapped
- High Flow Cats
