View Full Version : VQ35HR
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12
  1. Long Tube Intakes with no Tune? (Lean?)
  2. VQ35HR Vrs VQ35DE ?
  3. ARC Oil Pan AOPZ34 / VQ35HR compatible
  4. Stock z hp + tq to the wheels?
  5. @Stillen - air filter replacements???
  6. (Need Help) ARC Combo Catch Can, Need Instructions
  7. Track car cooling setup
  8. Resonation boxes on factory intakes??
  9. Here ya guy guys the hr plenum is here
  10. Test Pipes / HFCs Issues & Problems
  11. With age, how much will the HR lose?
  12. seafoam question for newer engines
  13. Stubborn intake hose
  14. Service light wont go out!
  15. Primary O2 sensors voltage (B1-S1 - B-S1) / HELP !
  16. VQ35HR CF intake manifold cover - Anyone interested?
  17. Clutch/csc replacement guidence
  18. anybody who has looked closely at the block
  19. Krank Vents
  20. Bouncing like a Moon Bounce
  21. quick question for those with AAM test pipes.
  22. 0w40 users - higher oil pressure?
  23. Baseline dyno = 294whp, what?
  24. rough idle normal?
  25. GTM Performance Engineering 350Z HR SUPERCHARGER KIT PRESS RELEASE
  26. Stillen supercharger system
  27. Primary O2 Sensor Replacement?
  28. Pictures of HR block
  29. Better place for oil temp sensor on HR
  30. HID Replacement
  31. Vq35hr on to de engine mounts
  32. Weird Idol when cold
  33. Motor oil problem
  34. 06 NISMO xhaust on a 07?
  35. VQ35hr rad question with a/t
  36. PIC Request. VQHR Cam trigger wheels
  37. People with AAM test pipes...
  38. gauging interest in a slave kit for the hr
  39. ATS Multi Disk Clutches for 07' Z?
  40. Headers for a HR
  41. Need Expert Advice on Set-up
  42. Questions !!! Help
  43. 4.08 Gears
  44. Dyno Results
  45. Fan Shroud for VQ35HR
  46. HR Tuning ...
  47. Loving my new HR
  48. SWAP VQ35HR for VQ37HR
  49. Berk Test Pipes v. Turboxs
  50. Rush Racing's Launch Control?
  51. VQ35HR swapped into...
  52. Projected HP output for Gamer's HR build!
  53. How much can I gain from upgrading cats without tuning?
  54. Underdrive Pulley for HR
  55. Exedy Upgraded Concentric Slave Cylinder!?
  56. Fuel Return System
  57. VQ37VHR kinetix manifold.
  58. How many times before its a lemon?
  59. Just got slave cylinder replaced... Change fluid at same interval?
  60. 0 oil pressure at idle
  61. S14 VQ35HR Swap
  62. Idle trouble..
  63. Mishimoto Racing Thermostat - not compatible with High Rev?
  64. Got my 07 Base Dyno Tuned at Specialty Z Yesterday
  65. help with check engine light codes
  66. Osiris on a VQ35HR
  67. Stillen y-pipe vs megan racing y-pipe?
  68. Uprev vs TechnoSquare, which would you choose & why for your HR?
  69. Oil Burning smell in cabin.
  70. 1200+horsepower VQ on the dyno!
  71. hr y-pipe vs nismo y-pipe
  72. Recent HR technosquare reflash... NOT running right, help!
  73. Please Help!!! TECH Help
  74. New Motor
  75. technosquare or osiris???
  76. stillen g3 or injen cai?
  77. stock cat bolts?
  78. heat from exhaust
  79. Exhaust and more
  80. Got test pipes/hfc's on your HR? Post in here.
  81. nitrous?
  82. Got my Technosquare tune
  83. Question about rattling noise + more
  84. Getting these next mods, opinions please? :)
  85. Vq35DE Vs VQ35HR Torque
  86. 07-08 wheel bearing/ hub
  87. Custom Intakes
  88. Drivetrain Upgrade
  89. Deciding between stage 2 GTM or Greddy TT kit for the HR
  90. ? how heavy the HR Z should be ?
  91. Got a Baseline For My Stock 07
  92. What's your oil pressure?
  93. Going to dyno later this week. Quick question.
  94. 07-08 cobb accessport flashing
  95. replacing the slave cylinder
  96. Exedy Clutch/Flywheel
  97. ? about oil. going away from role purple
  98. Coolant Leak - Suggestions?
  99. Header/Cat removal ?
  100. NA all the way
