View Full Version : VQ35HR
Pages : 1 2 3 [4] 5 6 7 8 9 10 11 12
  1. Pulley Kits on the HR motor
  2. Videos of mid350 350z 2008 GTM TT KIT.
  3. Amuse Hi-tech ROM
  4. HR aftermarket parts
  5. Idle issues when cold
  6. Is the VQ35HR that much better than non-rev up?
  7. Stock air box is best?
  8. Crawford HFC question
  9. HR motor + Nismo v2 bumper = rough/surging idle?
  10. Stillen Headers HR
  11. Clutch and flywheel... whos the best?
  12. VQ35HR Tranny's...Any difference between 07,08...
  13. HR gains from intake? (still false advertising?)
  14. Stillen or Crawford HFC's
  15. Y-pipe...
  16. STS Rear mount turbo
  17. vq35hr motor that needs more power
  18. Throwing Engine Coolant Code
  19. How to get 300whp+ on a HR
  20. Stillen Stage 2 intake
  21. VQ35HR 60,000 Mile "No More Warantee" Thread
  22. Clutch pedal noise
  23. hks hi power install question
  24. 2003 vq35de engine
  25. Valve body upgrade 08 AT5
  26. Alternative to K&N drop in air filters ..
  27. Plenum Spacers for the 08' 350z...are there any?
  28. 03 Valve Body same as 2007 ????
  29. good idea or bad on the 07z
  30. MVP Motorsports Berk HFC Install with Dyno and Video!!! 2008 350Z
  31. Oil change/Flush for low mileage HR
  32. track time on your turbo
  33. Just a couple of questions please..
  34. so any1 have a st/tt for their HR
  35. HR Swap | FL Z owner needs new block
  36. VQ35HR worth?
  37. Transmission Cooler Stillen or Mishimoto
  38. A solution for the csc (Concentric Slave Cylinder) problem.
  39. VQ35HR Radiator Cooling Panel - Color Options?
  40. Cooling Plate for 07+
  41. Help. I need HR Cylinder Head photos
  42. low-temp termostat
  43. I was thinking
  44. clutch sticks halfways up
  45. Injen Dual CAI on 08
  46. 2007 owners anyother issues besides slave cylinder & clutch?
  47. cats
  48. 6spd HR...Bolt-ons + tune (Dyno)
  49. MY exhaust set up is too damn LOUD!
  50. Aftermarket plenum?
  51. Stillen Headers (Pics inside)
  52. test pipe/hfc hesitation
  53. AC ON makes the car slower?
  54. TurboXs test pipes
  55. Aftermarket radiator for the HR...
  56. Finally Got My Car Dynoed
  57. Low oil psi anyone?
  58. loud clutch???
  59. VQ35DE past 100k miles?
  60. AEM, Fujita, or Injen Intake
  61. Looking to install Oil/Water Temp gauges and Oil Cooler, advice
  62. OIL PRESSURE READS 120PSI AT LOW RPMs
  63. VQ35HR Intake Manifold
  64. Problem I had at the Track
  65. JWT TT for the HR (Coming soon)
  66. Stock Flywheel
  67. twin turbo hr's
  68. Port and Polishing the heads?
  69. HELLO everybody new to the forum
  70. Resonated test pipes Vs High Flow cat
  71. How much brake fluid for brakes and clutch
  72. New to the Nissans, What are some good brands?
  73. Z's media share revised
  74. VQ35HR Represent!
  75. Y pipe is damaged
  76. baffled oil pan
  77. Rev limit turned off
  78. Tomei Camshaft for VQ35HR??
  79. 07-08 HR 350z V.S 06- 08 Mustang GT's?
  80. Oil change frequency question
  81. HR exhaust
  82. anyone dynoed their HR with hks exhaust??
  83. tuning for HR
  84. HR - represent !
  85. n2oHRZ banned???
  86. Why does my car make so litle power???
  87. Borla vs Bassani
  88. hr spark plugs ??
  89. Video of a HR NISMO rear mount turbo on dyno?
  90. AAM test pipes. A few install issues.
  91. Engine Mods?
  92. Berk Test Pipes Questions..
  93. Installed Injen Twin Intakes on my NISMO (PICS)
  94. clutch got too smooth...
  95. AAM 2.5inch HFC
  96. How important are the oem intake ducts?
  97. Stillen Super Charger for the HR?
  98. VQ40 block swap in VQ35HR Z
  99. ELF synthetic
  100. Cobb tune Or UpRev on 08 HR
