View Full Version : VQ35HR
Pages : 1 2 3 4 5 [6] 7 8 9 10 11 12
  1. Engine wont let me Rev past 2200 RPM techs are stumped!!!!!
  2. engine aesthetic
  3. Injen CAI with stock exhaust
  4. stillen supercharger??
  5. is there a CEL fix for the HR yet?
  6. Injen Dual Intake on my DB 07z
  7. 2005 350z base tune-up Plan (suggestions)
  8. 50-55 mph Whistle when cold
  9. VQ35HR Stock cats
  10. groundwire
  11. In Depth HR???(measurements)
  12. Apexi afc neo
  13. HFC's?
  14. Turbo Question
  15. Dynoed Today
  16. Lightweight Flywheel, Nismo?
  17. K&N vs Cold air intake
  18. where to buy berks
  19. The Drive by Wire issue
  20. AAM or BERK?
  21. Tomei Camshaft FOR VQ35HR
  22. Stillen update?
  23. injen short ram intake
  24. Procharger for HR?
  25. Oil change question
  26. cobb tuning access port
  27. hks tru dual and berks
  28. GTM Test Pipes installed; raspy as hell
  29. Cusco sway bar kit or F.I. HFC's?!?!
  30. HR Slave Cylinder Seal Broke due to aftermarket Pressure Plate
  31. Need some opinions on moding..
  32. Stock Air Filters
  33. 07 350z to 09 G37 coupe awd?
  34. What Oil are you running in your HR?
  35. have a chance to jump on an 08 z.
  36. hr guys
  37. Thoughts on these?
  38. power in the engine bay (to tap power from) when key is "on"/Engine Running
  39. what should I do next?
  40. Exhaust leak from AAM test pipes
  41. code: P2a03. HELP!!!!!!!!!
  42. bog + gears??
  43. aps 2.5inch exhaust dualor topspeed n1 3" for my twins
  44. Technosquare Reflash Users
  45. TurboXS Utec, standelone ecu
  46. engine rebuild, over 600hp. share ur experience/knowledge
  47. Changed my trans fluid, now it grinds 5th
  48. K&N Drop-In Woes?
  49. Need a new clutch need help
  50. HR intake Manifold
  51. Which Clutch (going FI 420-450hp)?
  52. Any Pictures of 2007 + Radiator Support?
  53. Recall on passenger side airbag sensors
  54. GTM HR swap in progress...
  55. 03-06 clutch fits 07-08 too?
  56. Pics of engine bay w/o engine covers
  57. clutch question
  58. Clutch Slave Cylinder on it's way out?
  59. What do you recommend....intake, or HFCs?
  60. HKS Hi-Power TI Catback with Stock 07-08 Air intakes
  61. NA Builds
  62. TopSpeed Pro 1 exhaust for the HR?
  63. How about Accesss Port Soft ware
  64. Dynocom vs Mustang Dyno vs Dynojet
  65. 07-08 differences?
  66. Oil Pan the same as the DE Motor
  67. GT Motorsports:350ZHRTT, GTM HR Turbo Kit STG 1,GTM HR ECU FLASH, Stock Block Testing
  68. A Diet For The Fat Lady?
  69. F/s HR Carbon Engine Cover/ cf Batt. & Brake cover
  70. AAM Competition Twin Turbo Kit
  71. HR + Berk HFC = Lean New DJ#'s
  72. Borla Exhaust on HR?
  73. Megan Exhaust on HR
  74. Final Dyno Numbers
  75. Good Exhaust Combo
  76. My VQ35HR is with UPREV for a week
  77. HR ques
  78. Bogging - stock car.
  79. hr test pipe non fouler fix
  80. tomei, arc on HR?
  81. 370Z????
  82. 3k RPM bog
  83. Finally got my Fast Intentions Intimidator and HFC's installed.
  84. Stillen oil pan, oil cooler, power steering cooler, and radiator
  85. 2007 Replacement Cats
  86. Stillen Header/ Cobb A.P. G37
  87. HR carbon or titan strut bars
  88. Dynos - Injen CAIs and Stillen HFCs - Not Safe For HR Owners :-)
  89. 03-06 Pressure plates DO NOT work correctly on 07+ HRs
  90. stock vs stock
  91. HR cobb accessport
  92. Wowwww
  93. POLL Should I pay someone to Install my Exhaust & HFC's or do it myself?
  94. HR Oil Temp
  95. HR Stock Clutch Strength
  96. let's say $4000 for HR! what should I do.
  97. MY CAR JUST UP AND DIED (opinions/help)
  98. Want to know the Max speed
  99. Greddy Evo 2 Exhaust
  100. JWT HD Clutch & Lighweight Flywheel Impressions
