- Header VQ35HR by Sunline racing
- got an '08 m/t base today... need some performance advice
- Wrinkle Red engine cover for HR
- 2007 1st Gear Noise
- K&N 69-7071TS Twin HR Intakes Released
- Test pipe is good for 5AT or not
- Fast Intentions
- Side exit exhaust?
- Installed Fast Int Res Test pipes
- Spark Plugs
- My dyno runs!!!!
- loss in pressure at clutch pedal
- Fast Intentions Resonated Test pipes
- Our are Injectors the same
- performance head gasket question (this might be stupid)
- Fast Intentions
- 07/08 Aftermarket Clutch?
- got back my ECU from Technosquare
- Regular Maintenance, ETC?
- vq35hr reflash for track driving
- high flows
- VQ35HR specific Zex Nitrous kit just arrived
- RPM wire for dyno
- Base line Dyno
- Technosquare Dealer in Florida?
- 08 Gearbox Issues
- Problems Starting the Engine (HR - N/A)
- 0-400 M what time that you got?
- Just got back ECU from Technosquare
- Running higher weight oil and oil pressure?
- Dual Popchargers - Power gain? Loss?
- K&N Dual CAI
- Where Can I Get My Tuning Done?
- Any power loss with the AEM intakes?
- Any after market clutch problems yet???
- Stillen grounding kit now available
- VQ35HR Turbo Build
- Clutch Pedal Click/Pop FIXED
- Wow I'm a dumb A$$!!!
- Injen True CAI for the HR!!!
- DE clutches do work!
- Unorthodox Underdrive Pulley Set Polished?
- Warranty ???
- Fast Intentions Resonated Test Pipes
- track
- My Review on Fujita Dual Intakes...pics
- Motul if it's so bad for VQ Eng why does Nissan???
- Download reflash through COM port??
- Clutch pedal click sound
- bad throttle body
- Performance Factory's Turbo'd VQ35HR
- exhaust opinions
- 2007 350Z Touring mods
- My car
- Throttle Body Stuck Open!
- what should be first?
- Berk Metalic HFC and CEL
- Cold Air Intakes?
- spec clucth for the 2007 is out????
- Performance Factory HR testicle/s transplant
- Had oil change today on my NISMO 08 Z
- Dynoed my HR with HKS
- My 07Z Work In Progress
- full aam exhaust
- 2007 350z Lowered with Tanbe GF210
- 309hp & 257.1 ft. lbs. Intake, Test Pipes, Emanage Blue - Dyno Plots Inside (Dynapac
- Which is louder???
- first impressons (JWT clutch/flywheel + APT TD 2.5)
- Berk Technology HFC
- Recall problems?
- My HR Mods
- so its been over 2 weeks
- Headers and Test pipe fitment
- Dyno Results
- Aps Td 2.5"
- new vid
- just came in (JWT clutch+fly)
- wtf is this?
- Arc Rocks!!
- Berk HFC dyno
- Oil changes... why so often?
- AAM 3'' TruDual
- Invidia
- Test pipes matched with Evo TT???-thoughts
- 07 dyno Fujita Intakes Injen exhaust 305hp 255tq
- Finally got around to scanning my dyno sheet
- Nismo Dual CAI FOR SALE (fits '07+)
- Noise after clutch recall job competed
- I am getting a JWT clutch combo tomorrow
- am i the only one
- This has probably been asked a million times.
- Vid- 3.9 gears before and after JWT flywheel
- Dynoed w/ aam test pipes, bassani exhaust, and kn drop in filters!
- SFR Engine Block
- Is it worth the money to put headers HR
- Whinning noise at 3-4k rpm... any idea..?
- OEM clutch/pressure plate
- HFC's VS TEST PIPES
- fast intention test pipes
