- Bad crank position sensor?
- CSC issue, Advise needed.
- Options : HR Y PIPE
- Some thoughts on the quote I got.
- APS Intercooled Twin Turbo (twin throttlebody) - coming soon?
- Need 350z Help!!
- need help
- need some 350z help
- Short Ram to Cold Air
- HR on a dynojet
- Problem installing test pipes on 350z HR motor
- Question about idle after start up.
- Lightweight Flywheel
- Crankshaft Position Sensor / Flywheel Issue
- Do you HAVE to remove the front brace to install intakes?
- My latest Dyno #'s
- Bore out a VQ35HR
- Every strut bar fits every year?!
- HR Stroker kits
- Stumbled on something
- Osiris ROM files - General Tuning Questions
- HR Throttle body spacers
- My HR Dyno Numbers...
- Castrol Oil & K & N Filter deals at Autozone
- HR dress up any one?
- should i worry???
- Test Pipe Question
- test pipes on an hr
- Jim Wolf TT Kit for the VQ35HR
- To all the Gearheads/Pros out there: RPM Surge/Buck during engine startup. HELP!
- Injen CAI vs Stillen CAI, pricing differences
- primary O2 sensor
- z06
- Stillen HFC on 350Z HR 313hp Italy
- Stillen Generation 3 long tube intake for VQHR
- OFFICIAL HR aftermarket clutch thread
- Engine dampener for HR?
- Mishimoto Radiator for the HR
- Loss muffler=loss power?
- To All my VQ35HR buddies
- Problems at the Track..clutch 18,3xxmiles
- Next Install project! Parts are in. Pics enclosed
- stillen long tube intake, good price...
- Pulley Kits on the HR motor
- Videos of mid350 350z 2008 GTM TT KIT.
- Amuse Hi-tech ROM
- HR aftermarket parts
- Idle issues when cold
- Is the VQ35HR that much better than non-rev up?
- Stock air box is best?
- Crawford HFC question
- HR motor + Nismo v2 bumper = rough/surging idle?
- Stillen Headers HR
- Clutch and flywheel... whos the best?
- VQ35HR Tranny's...Any difference between 07,08...
- HR gains from intake? (still false advertising?)
- Stillen or Crawford HFC's
- Y-pipe...
- STS Rear mount turbo
- vq35hr motor that needs more power
- Throwing Engine Coolant Code
- How to get 300whp+ on a HR
- Stillen Stage 2 intake
- VQ35HR 60,000 Mile "No More Warantee" Thread
- Clutch pedal noise
- hks hi power install question
- 2003 vq35de engine
- Valve body upgrade 08 AT5
- Alternative to K&N drop in air filters ..
- Plenum Spacers for the 08' 350z...are there any?
- 03 Valve Body same as 2007 ????
- good idea or bad on the 07z
- MVP Motorsports Berk HFC Install with Dyno and Video!!! 2008 350Z
- Oil change/Flush for low mileage HR
- track time on your turbo
- Just a couple of questions please..
- so any1 have a st/tt for their HR
- HR Swap | FL Z owner needs new block
- VQ35HR worth?
- Transmission Cooler Stillen or Mishimoto
- A solution for the csc (Concentric Slave Cylinder) problem.
- VQ35HR Radiator Cooling Panel - Color Options?
- Cooling Plate for 07+
- Help. I need HR Cylinder Head photos
- low-temp termostat
- I was thinking
- clutch sticks halfways up
- Injen Dual CAI on 08
- 2007 owners anyother issues besides slave cylinder & clutch?
- cats
- 6spd HR...Bolt-ons + tune (Dyno)
- MY exhaust set up is too damn LOUD!
- Aftermarket plenum?
- Stillen Headers (Pics inside)
- test pipe/hfc hesitation
- AC ON makes the car slower?
- TurboXs test pipes
- Aftermarket radiator for the HR...
- Finally Got My Car Dynoed
- Low oil psi anyone?
