- Catch can setsup - which one?
- 35K Boosted before it gave up. Help guys?
- Urgent AC belt
- The birth of a short shifter ---- TWM Performance
- i think my tranny is blown
- Rough Idle for 2 Seconds During Startup
- Engine stalls on the road while on idle
- Q? what fuses to pull that will allow the engine over WITHOUT starting it?
- Idle RPM too High; Tried Everything
- Dealing with Nissan NA - 2006 oil consumption
- Steering wheel fluid flush.
- Techs Please Help
- 05~07 oil consumption?
- Drive shaft to Diff question
- Help with C1143 code.
- Quik question about my transmission swap
- VK56VD swap???
- No ignition spark..HELP!!!!!
- need help identifying these plugs
- Replacing base non LSD with a LSD pumpkin
- clutchmasters fx300/ clutchmasters flywheel question
- Synthetic vs Concentional Oil
- Goodyear Gatorback belts
- oil consumption problem
- Differential: should i get an LSD?
- Clutch replaced after 16k miles
- Is it sufficient to periodically add oil?
- rear diff questions
- Tucking/moving main wiring harness
- Clutch is dead... Now what?
- Help Needed w/Engine Noise ID........
- Clutch issue or am i going crazy?
- Will an HR tranny work with a DE?
- Please Help!
- 350z throttle body reset
- New 06Z owner in need of some help
- p0021 & p0011
- Modifying the fidanza short shifter
- anyone knows about the os ts2bd clutch?
- Where can i get a tune?
- Which Oil Cooler is best for its price?
- clutch issue?
- Best Performance Mods for 350Z
- Slippage under Hard Acceleration?
- strange transmission request
- ecu reset
- Never wanted to deal with stealership
- help me diagnose my friends 03.5 g35 sedan
- Clutch needs replacement after 16k
- Final Drive and whine
- Please Help!
- Quick pumpkin swap question - orientation of cupped spacer / washer...?
- Freight "Portal" Shipping?
- I cant find the best flywheel weight for my setup!
- Trouble with Bleeding clutch (F1 Flywheel & Exedy OEM Clutch)
- Noise while going around corners from tires or drivetrain?
- Engine oil mix
- What Size AC Belt when using UR Pulley?
- Slight Idle/load Issue
- 1/2 STUCK AXLE NUT.....Any ideas??
- 2 years and finally on dyno
- Over Rev Valve Float?
- Innovate OT-2 LogWorks App
- Can't read my engine oil dipstick
- JWT Clutch Compared to Stock
- Shifter Problem
- 2003 350z transmission?
- Rear axel clicking, is the dealership trying to get off cheap??
- Cold Start Clutch Noise
- Clutch install
- Just finished valve guide seals...strange noise
- Rubbish fuel econmoy
- Which stock fuel lines to replace to run E85?
- Stillen front tower brace will it fit with a factory engine cover?
- Z33Art V3.0-LS1/TH400 Swap
- Engine rough idle and sounds out of sync
- Difference between 03/08 Clutch Master Cylinders
- Resurfacing Aftermarket Flywheel
- throttle body idle adjustment screw!!!
- 2nd Owner 06 350z oil consumption test and warranty
- Clutch gurus look here!
- Sikky 350z/G35 LSX swap
- turbo timer install help + gizmo shift light
- The WTF noise thread
- question regarding throttle body water bypass
- Replacment filter??
- Installed oil cooler, now outside ambient air temp reading incorrectly
- Oil pressure annomaly? Or normal?
- Power steering cooler installed
- Replacement clutch (OE or slightly better)
- Minimally invasive mods – Part 1 | ECU Tuning only results - dyno
- APS 2.5 test pipes ? before purchase
- Engine treatment problems and engine flushes
- 03' comes out of gear without the clutch being pushed...wtf??
- Need Help with Stroker Kit.
- low oil pressure?
- gforcechips
- Need measurements of ARC Oil catch tank V2.
- Help with flywheel
- Erratic idle on new engine
