View Full Version : Engine & Drivetrain
  1. Grease coming out from rear axle
  2. ls2 conversion (questions)
  3. Cd009 tranny swap please help
  4. Engine Overheating and No Cabin Heat
  5. 03 Z wont start....sometimes
  6. VK56 motor in a 350z
  7. wheel bearing issue?
  8. did i buy a 350z with a upgraded clutch??
  9. Terribly low trap speed, clutch possibly slipping? Not sure…
  10. 03Z Clutch problem
  11. clutch engangment lagging
  12. Redline now available for our Transmissions!
  13. Noise coming from vacuum hose
  14. quick clutch fitment question...please take 5 secs to help me out:)
  15. castrol syntec gear oil - differential
  16. Mocal sandwich plate quality...well..lack of?
  17. The tranny 3rd gear deal in an 03
  18. Engine just stopped while going 75 MPH!
  19. 230kw 350z how strong?
  20. clutch pedal clicks
  21. Does anyone know what final drive differential an automatic 2007 350z comes with?
  22. Dual throttle. Is it possible?
  23. Clutch packs for AT tranny?
  24. CLUTCHMASTERS Stage 2 OR Stage 3 ???
  25. ATS Clutches
  26. 4.08 gears Will this fit my 350Z?
  27. Fuel Pump failed! Cost for new one?
  28. JWT Flywheel Issue
  29. 03-05 vs 07-08 manual transmissions
  30. Ethanol 10 Fuek
  31. 06 Engine Swapped Due To High Oil Consumption?
  32. OEM Pressure Sensor Voltage
  33. Is it time to pull my engine?
  34. Squeky clutch pedal?
  35. My Vk56 Swapped 350z
  36. Aftermarket Oil Pressure Sensor position
  37. Power steering help
  38. Rod bolts
  39. Throttle Body Question
  40. Clutch Recommendation??
  41. Clutch/Slave Cylinder/ Warranty question...
  42. Does my Dyno seem accurate?
  43. Clutch Going Out
  44. crankshaft damper
  45. which is better?????
  46. Quick question..
  47. Torque wrench?
  48. Mods i have, the mods i ordered, and the mods i need
  49. Anyone Hear of Replacing O2 Sensor when Replacing Wideband Sensor?
  50. need some advice from my enthusiasts
  51. New Tranny Won't Go Into Gear After Sitting For a Couple Days
  52. HELP!! Noise from engine bay!
  53. What Can I Expect?
  54. Nismo Sports Clutch Kit
  55. Went to injected performance today for my Uprev tune
  56. Blown rear diff bushing
  57. Need help. Power loss.
  58. aluminum skid plate
  59. Quick question with fuel pressure regulator in cjm stage 1.
  60. **Need Help ASAP** CD001 to CD009 Transmission Swap
  61. Belts--Who Makes the Best?
  62. REVIEW: HR y-pipe on DE engine
  63. Nismo GT Pro LSD help
  64. New Clutch Kit Installation
  65. VQ35 timming chain
  66. CJM Stage 1 w/ Deutchwerks 600cc, What size rail spacers are needed?
  67. How can I clean injectors b4 I install them?
  68. Clutch issue
  69. What size fitting to use on stage 2 CJM fuel return
  70. Dash Light Issue - Intermittant - Car does not die
  71. Vibration while taking off in 1st
  72. UR underdrive pulley, now noise at 4400rpm
  73. PLX Kiwi adaptor for the Iphone?
  74. Cluth pedal vibration (pulsing)
  75. Any diff specialists around??
  76. weird rattling noise when my foot is off the clutch
  77. cam question
  78. Trans or computer??
  79. CJM Fuel Return System... Need help missing parts!!
  80. My 450Z Build thread - VH45DE Swap
  81. extended warranty may not cover transmission!
  82. Quaife stub shaft question
  83. Intake and exhaust for a 2008 350z
  84. ARC Oil Cooler questoin
  85. NISMO Clutch & Flywheel -- Info help
  86. where the hell can i get a slave cylinder for a 2007 350z!!!
  87. How do you clean Nismo filters?
  88. VQ35DE - VQ35HR or 37HR
  89. Power loss !!!, Only when it's HOT outside ...
  90. Synthetic Oil to Regular Oil?
  91. ProRacer ECON ignition system
  92. Poor Acceleration / loss of power. Help Needed
  93. got my z dyno'ed and I'm very happy with the results
  94. Grounding Kit Help !
  95. Lock out gear, and grind
  96. Transmission tapping, cylinder knocking..
  97. Need help with Cam/Crankshaft sensor question
  98. Underdrive Pulleys
  99. Water temp (HR)
  100. Yes, another auto to 6 speed swap thread
