- What the heck is wrong? Replaced batt, now won't start & SLIP, ABS, TCS lights on
- Noise and vibration while accel on bumps [HELP]
- 2003 350z idle problem
- New Transmission = New Problem?!
- Needle bearing in my valve train???
- loaded jack o' lantern
- Dual mass flywheel vs single
- Grinding while shifting?
- New to me 2006 with a pulsing hum.
- Codes p1273 and p1283
- Had to disconnect HKS Ignition, now the car pings
- Aftermarket Clutch Problems
- Quaife Engineering launches new six speed 750bhp rated gearbox
- Oil cooler & Gauges install
- Radiator HELP!!!
- Clutch Sticking
- installed new clutch now car wont start :(
- Clutch Issue
- Coolant leak...from where?
- JWT flywheel
- interchangeable?
- kaaz lsd installation, NEED help BIGG TiME.....
- What is normal Air Fuel ratio?
- Clutch Sticking top end
- VQ35DE or VQ35HR?
- ckp p0335
- clutchhh
- Built motor questions? Help from engine builders please/ knowledge on VQ builds
- Automatic transmission - delay in reverse
- Possible misfire?
- Coilpack Wireharness connection order
- benefits of the nismo thermo?
- How can you tell if the starter needs to be replaced?
- Where does this ground strap go
- PSA Wally World and Mobil 1
- redline MTL and MT 90
- 2003 nissan 350z Timing chain tap on cold start
- oil pressure gauge messed up?
- 5W-30 to 5W-40 will cause higher oil pressure
- hks and heat wrap
- My dads car needs a new transmission, can anyone throw me some advice?
- Driveshaft/Axle Bolt Replacements???
- having trouble bleeding the clutch
- VQ35 Bad Crank Angle Sensor? $700 from Dealer?
- Oil Block
- Intake Cam Sprocket. I have a Question.
- 350z textpipe....
- strut tower bar nut size
- OS Giken clutch doesn t disengage
- Rear differential bushings?
- clutch switch
- VDC and slip light
- Random Sputtering/Misfiring
- 30 gallons of c10
- You know its gonna be a good night when your clutch completely goes out...
- 04' Z engine swap into 04' Murano
- High pitch noise
- Should I send back to get replaced
- ??What is the leanest A/F for VQ35DE??
- SS clutch line installation problem
- Performance Parts Suggestions
- 04 350z will only idle. Dies when try and rev
- Tomei diff noise.....not normal
- Need Clutch "Kit" Help
- 3.3 final gears vs 3.5 final gears
- weird squeeking noise
- best 03 clutch kit?
- Buying and Replacing 03 Transmission
- Consult 2 didnt work......what next?
- Engine Code or Serial Number
- 07 g35 6mt clunking
- JWT clutch/flywheel combe noise at low RPM
- Looking for some low end power without FI?
- Double Clutch Methods
- Help with noise(s)
- 2003 modding tips....
- Oil Cooler Help
- shifting to cd009 from cd001
- throw-out bearing needs to be replaced...
- Need Help with Clutch
- Clutch Pedal Sticking - after searching, it's a followup ?
- 120MPH cabin pop???
- clutch sticking when lost traction
- Low Coolant?
- multi pin bulkhead connectors
- Rough shifts after VB change on 5AT
- 70k 03...turbo, sc, or n/a
- apexi neo afc install
- What's up with my oil pressure?
- 350z and e85
- i need help with some spacers
- Question on AFR tap
- Does VDC affect Clutch Engagement?
- Head Gasket Suggestions?
- 5AT Transmission Pan Bolt Size
- Synthetic Oil
- 3.5VLSD Swap
- Arc Catchcan V1 question...
- Best bang for the buck oil cooler?
- Tools to measure crank journals and ID of connecting rods
