- Towing on a 2 wheel dolly - question
- First LS7 350z
- Avid racing eng and trans mounts
- 87 octane cel p1283
- car smells like burnt after driving hard
- Clutch problem?
- Cheap fuel rail adapters?
- HKS Hi power. any users?
- diff problem?
- Cooling System Questions/Modifications
- Any idea of what could be going on?
- need some radiator help
- Cd009
- need a quick answer in the middle of a project??
- P0340 drivers side or passenger?
- Flywheel choice
- What new under-hood Performance Parts would you like to see from COBB Tuning?
- Need Help with Greddy Oil Block Adapter and STRI
- Upper Oil Pan Replacement - Different Generations?
- Would 87 octane gas through a cel?
- OEM Radiator cap pressure???
- Gas light on WITH gas
- 5/16 Plenum Spacer Problems
- 350z Radiator Fan Switch - lower temp?
- CAMP2 Help
- Transmission seems hard to put into gears
- copper turbo kit piping
- Dimensions of DE & HE lower intake?
- my list of genral newb engine questions i need answered
- stripped flywheel bolt
- anybody sell turbo kit piping
- JWT Flywheel with 300ZX TT clutch
- Airflow meter service ?
- My first engine teardown
- Jwt clutch flywheel combo
- Strange Burning Oil Smell during WOT....
- Anyone ever do an individual throttle body setup
- Coolant leak?
- Synchromesh???
- Hole in my Diff
- i picked up an extra motor but i need some help
- What clutch should i get?
- hot starts on my vortech
- Trans to block bolts
- Venom 400 Chip
- Trouble starting Z after spinout
- Thermostats
- Reverse won't engage
- Intake/plenums for a VQ40???
- Steering boot grease
- Help with the Service Engine Soon, VDC, and SLIP light on
- question about dual intakes
- discussion about octane additives
- hey guys have a couple questions about my motor..
- engine dies
- Sounds inside the Z
- New ECU Upgrade
- Built automatic transmission
- AMSOIL GL-4 Transmission Oil for 6MT: Anyone used it?
- Primary O2
- car bogs down
- Strange Idle Squeal
- Replacing Valve Stem Oil Seals - question
- Stripping ECU/ECM of BCM/IPDM/ignition dependencies
- VQ35DE shortblock
- Dyno Results...
- Oil Pressure????
- I really need help and quick plzzzz!!!!!!!
- Rear O2 Sensor
- Car dieing after startup
- Water pump question
- JWT FlyWheel Help please
- Loose Bolt on Rear Axle
- Welded vs tomei 2way
- need a rebuilt motor or used!
- Nismo radiator cap question~ please help
- What could cause stub shafts to pull out?
- Rev matching downshift (DRM) question
- Anyone who has hks groundking kit on their engine bay? Needs pictures/guide
- P1121 code...anyone? Also cluster lights are on.. (CEL, SLIP, VDC OFF...)
- LIfts & JK stands
- How bad was this for my car?
- 135,XXX on original clutch... is it on its way out?
- bleeding my clutch
- Oil Sandwich Plate Thread - Where to buy?
- Underside of cilinder damaged?
- Help with engine problem!
- DIY Coolant Flush/Refill?
- Differences in 5AT between 2003-2005?
- 2006 350z Dyno on Dyno Dynamics
- Confused with the engine.
- Replacing 05 VQ with 07 VQ?
- so life span of a 6mt?
- aftermarket clutch?
- Boggin down
- How Do I Tell If I have a Rev-Up Motor when I did a 2005 motor swap?
- sleeve dropped, cheaper to repair or by Sharif/forge bottom end????
- ring & pinion
