- crankshaft sensor
- Is the Quaife LSD a 1.5?
- strage noise after shutdown
- Auto and 6-Speed LSD interchange and gearing
- Transmission or clutch?
- Problem with gauges!
- check engine service light came up! help!
- Air/Fuel Mixture
- New to Z world, tranny consern 2008 Enth
- resonator muffler
- Have an Exedy stage 1 clutch, need help selecting flywheel
- 03 Transmission, rebuild or new CD009?
- SES, SLIP and VDC light on P0335
- What extra gaskets/orings are needed when replacing head gaskets?
- 5/16 spacer install. idleding problem.
- Keep DE go HR or go SR?
- Need help on removing rusted exhaust bolts!
- Sprint Booster Review
- Bone stock '07 350Z (VQ35HR) meets the Dynojet
- will an 05 non rev benefit from an merv2
- Got my Z back! THX SPEEDforceRACING!
- 2nd gear notchy feel & linkage noise
- Anyone running 4.11 gears?
- new motor
- Major clutch problem...so confused!
- stillen torque damper
- 03 350z accelerating problem please help!
- any difference on tranny internals?
- Southbend Clutch. Who else has one?
- Auto trans swap to 6 speed manual question
- Is this a MT or AT crank shaft end
- Gears or Flywheel upgrade?
- 4th gear hesitation
- Coolant Everywhere...Help!
- driver side bearing
- Final Drive/LSD Problem
- Who has rebuilt a diff on a Z?
- aftermarket LSD with VDC or TCS?
- ATF change DIY or dealership?
- Just bought a CD009
- Aftermarket valve covers w/ replaceble gaskets
- Weird sound
- clutch pivot ball failure rate on CD009
- Plastic part under car.. where does it go?
- Adaptor for fuel line quick-connect?
- O rings
- Yet another clutch issue 05 enth
- wtf?? seriously, where does this pulley go??
- Infiniti G35X 2wd mode??
- 1 or 1.5 way LSD
- Alternator pulley swap
- Using diesel motor oil
- -Catback=burnt valves?
- just finished my jwt/clutch flyheel, clutch is sticking please help
- gearbox problem
- Best 350z year to buy?
- ACT SS full face clutch kit weight
- P2A03 Gremlin from Hell
- camshaft position sensor code
- Final Drive Question
- What would you do?
- Question for JWT flywheel people.
- hose on top of 350 tranny
- Going Back to Stock Flywheel...
- Manual transmission weight
- last question bout my jwt clutch install
- dyno compilation?
- removing throw out bearing
- Scott Performance Camshafts
- Cam Position sensor Code P0340 HELP!!!
- New Spec Super Twin Clutch
- Powerlab 3/8's, Strut, A/M Hood Clearance.
- Which TP/HFC mounts..
- Do all VQ35DE's use the same ignition coils (G35, Altima, Maxima, etc?)
- Estimated HP
- This guy says 4.083 is slower than stock
- Clutch Pedal sticking
- change oil light
- A Little Better than OEM Clutch?
- Dynojet Run by a 350z with few bolt ons
- question about the clutch
- question: just install jwt clutch & flywheel
- HELP!~ underdrive Racing pulley
- jwt clutch/flywheel installation time
- 350z vs maxima engine
- jwt cluth/flywheel adjustment tool?
- High Temp Wrap
- clutch issue
- Flat to pistons in a vq35de? help
- high rpm 350z
- test pipe issue...
- Help: transgo vb upgrade
- Get rid of the fuel cut for spark cut?
- High Pitch Noise from inside oil pan area.
- Engine Power Cutting out at apx 5,700rpm's? Any help?
- A/c delete
- how long untill OBD2
- Rough idle
- Engine Stalling - Help
- rev up cams?
