- rev up cams?
- AAM Stage 1 fittings and lines
- VVT control solenoid or sprockets!???
- Electronic/Engine
- motor mounts? does anyone make them?
- Vibration in clutch.
- differential bushing install
- Tachometer jumping around after clutch and flywheel install
- Middle bolt broke on pressure plate install of new clutch....
- How do you remover the power steering pulley?
- VLSD Conversion
- hyperforce install need help
- DE/HR clutch interchangability
- Clutch Problem PLEASE HELP!
- Annoying vibration vibrating
- Broken Pivot Ball
- Clutch and Flywheel???
- RPS clutch info please
- Shifter Problem. Help guys.
- 5AT - Torque Converter Group Buy?
- Clutch project problem with welded bolts
- Transmission problems?
- Would this call for a Tune
- $150 vq!
- Help!!! Questions about flywheel/cluth combo
- Engine grounding kits?
- HELP Diagnose my Z!!!!
- Compression Ratio Calculations, Cosworth F'UP or mine?
- Overheating Issues
- 350Z Engine Block Heater
- oil and filters...
- Limp mode Fuel cut P0304 P0340 P0057 P0011 P0021
- Has anyone tried these motor mounts???
- Just installed K&N filters..
- Howling noise from CD009 transmission
- Fuel pressure??
- Oil Pressure Gauge shows 120PSI on start. How big a problem?
- Need Motor Mount install Help...
- 3rd gear synchro needed.
- ECU cross over question *please help*
- sad... car can be "shifted but" does not go anywhere... Clutch issues HELP DIAGNOSING
- Stock 2005 Non Revup 350Z revs to 7000k RPMs?
- Automatic Transmission (A5) Pan Drain Plug Size?
- help for 03 transmission
- Had a boo-boo
- Stiff Steering
- Sound Performance Differential Brace kit!!
- Just Installed JWT combo-some questions
- OK something someone has probably answered
- Check engine soon. Can't go higher than 2k rpm
- Cylinder #1 Misfire
- Just purchased a 2005 touring 6 speed..???'s
- Best Mods to make car faster?
- Chattering NOise!!
- Is it pointless to get a HKS?
- 07 350z Release Bearing
- broken bolt
- SCCA sanctioned drifting-need VDC advice
- weak starting
- Help with Crank Pulley needed
- Help! Car overheated after small fender bender
- Short Throw Shift. HELP ASAP!! Please
- motordyne intake spacer switch?
- stock pressure plate w/ aftermarket clutch disk?
- Will a stillen engine damper fit with a Greddy tt kit?
- drove with bad clutch till it died
- Clutches, Flywheels, & Steering Racks...Oh $$$$ !
- 4.083 Gears
- Is it possible to make the auto tranny faster?
- Performance Mods
- Knocking or tapping noise??
- engine wont start need ideas???
- Pulley Question
- Bolt ons and cost of getting dyno testing
- p0455 while snowing...
- Grounding kit
- TOMEI EXPREME V.2 on VQ35DE REv up /VQ35HR
- Clutch help needed
- Bank 1 engine camshaft sensor location picture request
- Pulling tranny
- 240sx Final Drive Gear in a 350Z Diff?
- Carbonetic/ATS clutch kit for HR
- Can i use my Walboro 255 with a stock setup?
- Time for a new clutch!
- NISMO CAMSHAFTS - Help
- Ripped Differential Mount!!!
- VQ35DE Piston and Rod Weights
- Bad Oil Pressure Sensor?
- new wheel bearing bad after 50 miles??
- SPEC billet steel flywheel problems
- Does the 350Z have a "brake-to-idle" system?
- ARC oil catch can question
- Dimensions of VQ35DE Revup Motor
- SUPER WERID CLUNKING NOISE !!! ANNOYiNGG !!
- Help! Something is shaking under my car.
- Where can i buy this connector?
- Oem vsc lsd diff problem
- RMP to high
- 6 speed trans weaknesses, if any?
- 5AT feels very sluggish, needs 2.5kRPM to start moving???
