View Full Version : Engine & Drivetrain
  1. Revup engine question. Cylinder bore questions.
  2. ecu and harness
  3. Rear Differential Fluid
  4. VQHR: Which one is the upper radiator hose?
  5. Need to replace engine, will a G35 Coupe Motor Be a Direct Swap?
  6. Limp mode
  7. Transmission Issue - Need advice/help
  8. Who sells Cusco 80w90 gear oil here in US?
  9. HKS Twin Power DLI II CARB EO sticker
  10. 370Z pumpkin on a 350z?
  11. wanna add a air bypass valve on cold air intake
  12. Does anybody know anything about what a spline is in a tranny
  13. Complex Code Failure G35 2003 SEDAN
  14. Anyone with a Successful Mishimoto Oil Cooler Install
  15. What did I do to cause this?
  16. Anyone know how much the stock axles in an 06 will hold??
  17. Picture of Engine harness on a removed engine
  18. ae86 with a VQ with problems...
  19. compression ratio & octane 91
  20. Revup Block conversion?
  21. Got a couple of transmission questions...
  22. Help: Transgo for 350z AT5 2003
  23. Auto tranny anomaly
  24. Potential tranny issue?
  25. What synthetic gear oil should I use???
  26. Bushing on crank on one motor not on the other? Help please.
  27. 03 sound in the transmission when I release the clutch in neutral
  28. A/T tranny failure!
  29. What to get next for hp?!..
  30. Clutch recommendations?
  31. Please help !!!!!!!!!!!!!!
  32. Traction control question
  33. What is causing this clutch issue?
  34. Which vendor sell OS Giken Super Single Clutch Disc??
  35. Oil Pan Replacement Question
  36. what clutch with CD009 transmission? need help ASAP
  37. Time 4 another round of "Name That Sound!"
  38. DRM (Down Shift Rev Matching) for Auto Trans
  39. vq37 swap into 04 z
  40. act streetr litre flywheel???
  41. 03' Z making skreetching noise
  42. Revup Heads on a DE ?
  43. Downshift Rev Matching 350z A/T
  44. Clutch, Tranny, and Timing issue? with a twist.
  45. hi everyone i need help please!!!!
  46. Need fittings for the Nismo lsd and the differential - help
  47. PLEASE HELP. p0345 issue.
  48. How do you know if you're out of Antifreeze/Coolant
  49. Short throw shifter
  50. New Grounding kit......
  51. Nissan's Bleeding Trick
  52. Oil Cooler on N/A
  53. Over heating issue update
  54. Built Engine?
  55. Southbend DxD Clutch New Product Release Midweight Billet Steel Flywheel
  56. resonance frequency
  57. Enthusiast LSD into Base?
  58. 300whp?
  59. 2003 trans noise
  60. 2003 engine swap information
  61. The new GC?
  62. Exhaust sounds hesitated
  63. is this normal idle oil pressure?
  64. Fuel injector ID help
  65. Need opinions for rods.
  66. what do you think?
  67. Need help with a/c please read
  68. Weird Squealing noise
  69. 06 oil problem?
  70. No oil according to dipstick
  71. 04 AT5 tranny in a 03 ?
  72. quick question about test pipes
  73. Can I reset the ECU and pass emissions with a CEL on?
  74. Engine Wire Tuck DIY Request =D
  75. Will This Inline 6 Swap Fit?
  76. Tranny replaced under warranty...
  77. What flywheel and clutch set up for drag and street?
  78. TT project Need Helppp!!!!
  79. At what mileage did you replace your Z's clutch??
  80. Adding shim/washer inside VLSD diff?
  81. Poor gas mileage...
  82. need help idk whats wrong and its driving me up the wall
  83. A little whistle sound at 65 miles?
  84. Trouble starting her up (see video)
  85. Car dies out when starting after pop charger install
  86. Where is the oil pressure sensor located?
  87. oil pressure problem...
  88. How to put feeling on the clutch?
  89. Just installed JWT clutch/flywheel and i need your help
  90. Pinout!!!!!
  91. blowing engines?
  92. oil cooler kits
  93. 03 trans issue. arming myself for dealer.
  94. already i need help
  95. Is This Normal?
  96. Oil Cool Install
  97. problem with engine, don't feel right
  98. Problem with car
  99. New Shifter Cup - Where to buy?
  100. Knocking changing gears
