View Full Version : Engine & Drivetrain
  1. Need better fuel economy:breaking the bank
  2. Help with engine Being Rough Idle
  3. Transmission issues
  4. Potentially more Final Drive options.
  5. 08 z weird clutch
  6. Problem with Nissan
  7. crack on friction plate
  8. driving without hood ques
  9. Anyone installed a Works Bell Column paddle shifter?
  10. Hmm amsoil~~~ am i over doing it?
  11. Abnormal startup
  12. Uprev tunning vs. Cobb Tunning
  13. OEM clutch/aftermarket flywheel
  14. Drain Plug Washer problem...
  15. need help with ignition coils
  16. timing chain tensioner
  17. Identify this LSD
  18. Oil cooler and warranty?
  19. vq35hr/vh41 bellhousing fitment
  20. Earl's Hoses and Fittings
  21. Fuel Psi Issue
  22. Diameter of radiator hose
  23. does octane booster really work?
  24. Ticking Noise ??
  25. 04 manual transmission fix, now has extremely loud exhaust drone after repair (+vid)
  26. g35 sedan need some help
  27. anyone with a works bell column shifter ???
  28. 3 Nissan dealers later.. NO ONE knows the problem... HELP!
  29. 3.90 Drive Gear
  30. Warm start problem- revs up and drops to ~0
  31. Dealer wants $1700 for clutch+flywheel :(
  32. Popular Fuel Regulator Comparison
  33. Loud noise coming from front of engine normal?
  34. hr and de flywheel differences
  35. non rev to rev up swap
  36. Clutch just went, on hr
  37. Cranking issue...throttle relearn or no? HELP
  38. Had OC...going to buy GTM stage 1 shortblock...will my stock heads be fine???
  39. Clutch knocking or ticking sound
  40. Bad carbon buildup
  41. Pumpkin swap question
  42. Engine Tick!
  43. How much does it cost to Swap a Long Block? Also Need Long Block PREFERENCE!!!
  44. Z overheating...
  45. Concept G for 350z
  46. Blew Second clutch line same problem
  47. p0171 bank 1 lean and car stumbles under wot and feels down on power
  48. think i got got scammed by a member
  49. 2005 Engine Overheating
  50. Anyone know where this goes?
  51. What's the difference between " JWT S1, S2, and C2 Cams"
  52. swaped a non rev for a REV UP now problems... help!
  53. Shifter Linkage
  54. 03 350z 6mt problem when turning off
  55. Buy a Used Engine or Rebuild Engine
  56. VQ35 Or RB26 DTT
  57. blown motor
  58. e break light comes on during hard shifting
  59. Rev up motor vs non rev up motor
  60. Jerking/ Hesitation at cruising speeds.... HELP
  61. camshafts Question
  62. CuztomPartz/Southbend DXD Clutch needs test car 07-09HR/370Z
  63. Noise I can't figure out - Please Help!
  64. Curious burning smell after driving
  65. 2003 / 2004 engine swap
  66. UPDATE on my '03 Z now the problems start
  67. Steering Free Play
  68. Tech question needing an answer.... errr.. something!
  69. backfiring
  70. engine idle noise
  71. parts
  72. Help with white smoke and Bogging issues??
  73. Oil temp off factory ECU
  74. cam sensor positioning
  75. Help me identify this noise
  76. Problem with Build
  77. Restoring Performance in my Z
  78. Best price on Transgo 5AT Kit ??
  79. 06' 350z overheat
  80. p1281
  81. gear swap
  82. need stock engine build
  83. P0300 random misfire with search
  84. rough start
  85. GTM Valvebody Upgrade Issue?(car towed)
  86. Question about my supercharger and intake...
  87. Engine power cut (Rev limiter)
  88. damper in the clutch?
  89. help?!?!? my baby is dying slowly??? i postd in the wrong section before i think
  90. Cooling problem
  91. How much HP should I have?
  92. clutch bleeding problem
  93. DIFF FILL PORT THREAD PITCH?? who knows?
  94. Weird issues.....
  95. Avid Racing Trans mount???
  96. Quaife LSD Q!
  97. Noise in the valve tran:((
  98. my project - vq35hr powered s13 240sx
  99. Who sells 3.7 FD?
  100. 2007 350z 5AT question about cold stutter
