View Full Version : Engine & Drivetrain
  1. weird throttle issue. Help, I need some opinions.
  2. Is it safe to jump start your Z?
  3. 06 base...in the winter??
  4. 04 motor in 05 chassis
  5. anyone know anything about our fuel pumps?
  6. transmission ideas for enduro car
  7. Gears Grating When Going Into 3rd
  8. LSx Swap questions
  9. Weird throttle Delay at 1500 rpm
  10. BIG problems!
  11. Which LSD for an '08 Base 6MT?
  12. New Intake Manifold Gasket needed?
  13. AeroForce Interceptor scan guage
  14. 06 with bolt on's First DYNO
  15. HELP - Weird Whining Noise When Cold
  16. How do I remove the timing cover and oil pan
  17. Auto tranny cooler?
  18. 350z wide band WHERE I CONNECT IT????
  19. 3.9 or 4.08 gears
  20. Exhaust
  21. f1 racing clutches
  22. Has Anyone put this in their Diff?
  23. damn! road kill
  24. wont go to first gear??
  25. my $9.99 lower engine planel
  26. Spark Issues!!!! Help!!!
  27. upper plenum
  28. vibration while not in gear
  29. Slight oil consumption on a non-rev up na VQ35 question
  30. 5AT...harsh shift in manual mode...Help!
  31. 06 Long Block Swap
  32. Questions about Transmission...
  33. not a typical clutch question
  34. My clutch problem WITH VIDEOS!
  35. Burning Alot of oil ...03 touring..
  36. How in the world do I read the ATF dispstick?
  37. RB26DETT swap in 350Z?
  38. MD Plenum Spacer = SES light on.
  39. Whats one bad VQ35
  40. Vdc, slip lights with long cranking time?
  41. Swapped engine from 04.5 to 04
  42. Product Review - Coastal Metals Cooling Plate
  43. Engine and Trans removal
  44. What main bearings do you recomend?
  45. Is it worth molly coating you pistons?
  46. Nismo LSD help!
  47. Modification Plan for 2k+6 (try 2)
  48. LSD Swap from trackedition to Basemodel open differencial - what do I need?
  49. pulley question
  50. Z Drive Shaft??
  51. Help/Info/Opinions - POA!
  52. Shifted into Reverse while driving (AT)
  53. Dyno a bit low?
  54. cams question
  55. Lifter noise, oil consumption, 52K miles, 5 yrs 6 mo old
  56. at 30k miles is it late to change??
  57. New fuel pump
  58. hmm... looking for an aftermarket clutch
  59. First Performance?
  60. Titanium Bolt Upgrade! Big Ballers in the House!
  61. Oil catch can....?
  62. OS Giken vs. Drexler LSD
  63. Jerkiness due to 6 speed manual gear ratio
  64. Who makes the 6-spd transmission for the 350z?
  65. Where can I buy 3.9 FD?!
  66. ATF Cooler Installation Question
  67. vk56 swapping the g
  68. Squealing on startup and reverse
  69. Dexron-VI is better than J-Matic
  70. Problems with basline dyno
  71. I've failed at search
  72. Questing about wiring the to the ecu!
  73. After Market Clutch Opinions
  74. Manual Transmission fluid change in '06
  75. Clutch Sticking! Anyone?
  76. 03 track 350z got timing belt or chain?
  77. More throttle body issues...
  78. Oil/psi question ?
  79. 2005 with oil consumption :(
  80. HFC caused CEL- temporary neutered engine output?
  81. Cooling plates
  82. Help Finding Thread Adapter
  83. Scrap VQ35 heads needed to prove out CNC program
  84. How well is the OEM VLSD supposed to work?
  85. Project Kics engine drain plug
  86. Noise i can't figure out?
  87. need this fuel part... HELP!
  88. Clutchmasters FX400 Stage 5 Clutch
  89. Differential side flange installation
  90. Missing Nipple Piece on Plenum.. Replacement?
  91. anyone running breather tanks? need help
  92. Oil consumption
  93. Does anyone know the sizes of these mufflers?
  94. Technical Service Bulletin 2004 Z Air/Fuel Sensor
  95. ENGINE SPECs
  96. stock 6mt transmision able to withstand how much bhp?
  97. Serious MAF Issues
  98. clutch line on my Z
  99. Whine Noise Coming from the rear
  100. Power steering pump!
