- Need Vacume hose diagram.
- Diff Backlash Spec's
- turbo or replace transmission?
- coin compartment heat
- Tech Help Please - Diagnosis with Engine Idle problem
- Electronics saved my motor last night
- AC Idler Pulley Help
- Performance on Stock Revup
- Using Royal Purple Gear Oil as a top off
- Service Engine Soon, TCS OFF, SLIP!! HELP PLEASE!!
- SLR Perfomance chips?
- What is cold idle rpm for 2008 Nissan 350Z?
- New CD009 installed w/ ACT 6 puck sprung
- wiring help....
- For those of you who have replaced the OIL PRESSURE SENDING UNIT- is this it???
- 2003 swap to 2006 350z heads
- '07 Transmission in an '04... Help!!!
- Engine Failure Question
- with drawl lever ball pin
- Fuel Problem...Need Help!!
- Not Much Power to Start The Engine
- What vq35 is this
- Tranny sounds on wot?
- Part #'s for pathfinder coolant mod
- 400Z or G40...VQ40DE!
- Yeap another one with clutch issue
- Clutch will not return all the way up!!!!..help!!
- Late clutch? + blacked out headlights
- 04' vq35 quick general questions
- Gas Octane
- Hydrolocking from cai's on HR motor
- Engine Revs By itself
- Shifter Linkage Pin Removal
- Stupid Question. What type of socket is used to remove the girdle bolts
- I need a advice for my 350z 2006 plz ,, =)
- Engine Oil Sumps. Who does Baffled ones that work?
- Shaky shift knob?
- Heat question
- Spark Plugs
- Pic request: Stub shaft snap ring
- how long does the stock clutch last?
- Base Pumpkin install into Touring VLSD?
- in need of a Mocal Sanwich plate adapter
- Airbag light is always on
- new trany
- 2nd to 3rd shift noise
- VLSD worth...
- Free Floating Flywheel
- Clutch Issue
- 350z garret gt40 build
- Carbonetics LSD OIL?
- Engine/Clutch Problems
- 3.9 Final Drive Whine
- Throttle body failure
- Aftermarket Clutch and Slave Cylinder
- Lsx 03 350z
- 2003 VQ35DE Block Worth?
- Solid rear axle conversios question
- Nismo lsd
- HKS EVC Wiring
- whats wrong with my diff?
- Am I heading for gearbox failure?
- Cold weather budget build
- Diff cooler help
- Question
- Diff question.
- Running lean
- why does the z needs a oil pressure gage
- 3.5 FD pumpkin is here!!!
- Eaton Clutch Supply?
- Clutch help
- dumping the clutch issue..
- Mobile 1 Vs Castrol Edge?
- Full Synthetic Oil for 2006 350Z
- *Clutch and Flywheel Combo Good For NA and FI*
- Official Short Shifter Review/Poll/Rant Thread
- vq35hr
- Stalling Engine
- Anyone know the size and pitch of the bolts on the bell housing
- Reservoir Caps
- Differential Case Dimensions
- crawford plenum dressup bolts or washers
- Thoughts on smoke (vids included).
- oil gauge
- transmission Whine
- timing chain help
- Pumpkin interchangability
- Engine Noise- Help ME!!!
- help
- weapon r coolent tank
- camshaft position sensor
- Crank Bolt Question
- 256 rwhp no tune on an 06'!!
- difference between rev up and non rev up engine
- 04' Viscous limited-slip differential (VLSD)?
- High water temp on hillclimb runs - Problem at Track Day?
- running lean
- Mishimoto Radiators opinions anyone?
- Goods n bads of Oil
- engine noises when accelerating
