View Full Version : Engine & Drivetrain
  1. brakes??
  2. clutch
  3. Bolt ons?
  4. P0340 Code Thrown Plus Other Electrical Issues
  5. best clutch/flywheel combo
  6. Engine suddenly won't run above 2,500 RPM
  7. Which motor do I have?
  8. Enging running hot?- New Z- Am I just parenoid?
  9. whats wrong with 2nd gear?????
  10. No more 3rd gear!
  11. 03 transmission under warranty?
  12. Jeremt Tibbs
  13. 350z idle
  14. Na bhp
  15. Rev-Up Oil Pump - Confirm part Number
  16. Just had 6Spd Tranny Fluid Replaced- Shifter/tranny running hot.
  17. New exhaust causing hesitation problems
  18. Worn piston rings :(
  19. rev-up or non rev-up
  20. ACT Streetlite Flywheel - Holy Cement Mixer!
  21. Too late to install a Transgo kit?
  22. Borrowed Mr. SBC's DIY Writeup for a Power Steering Cooler install & ended up w/ this
  23. How much are these cams worth?
  24. Clutch worn down at 32k?
  25. Z hesitates when I give it gas
  26. what is rev up??
  27. Oil Pressure Guage Pod Reading 120+ CONSTANTLY
  28. sound sketchy??
  29. Search failed me again -- how are cylinders numbered?
  30. Codes on my Z
  31. Experienced? on your intakes whats the best!!
  32. timing chain help
  33. 2005 350z transmission PROBLEM HEEELP!!!
  34. Help! Weird Noise at low RPMs
  35. manual transmission, trouble shifting into third gear.
  36. WHY does other 350Z sounds louder than mine?!
  37. Compression Test
  38. Battery and Brake light On... why?
  39. where is 350z ECT relay????
  40. Oil Pressure
  41. Power Loss, Help with trouble shoot?
  42. Ok, so now my car is gutless...not cool.
  43. Jwt tech clutch install
  44. 5/16 spacer
  45. DIY fuel injector install ???
  46. 6MT clunk when letting off gas???
  47. Clutch Problem
  48. '03-'08 engine spec chart?
  49. Why does my throwout bearing keep going out?
  50. New tranny from dealership is not CD009??
  51. HELP! Car won't start! Electrical fix? PLEASE LOOK
  52. 06 Touring 6MT clunk noise
  53. EGR Valve Location?
  54. ARC V2 oil catch can drain direction
  55. Please read. Cars freaking out
  56. any suggestions..?
  57. CEL & Rasp/Gurgle @ 2.5K-3.5K RPM?
  58. 06 oil question
  59. Billet throttle body, what size to make for my application?
  60. Antifreeze/Coolant Confusion
  61. Why I go to my350z when I have tech issues
  62. Need help Oil line for Greddy TT kit
  63. Horsepower Show-off Thread
  64. grinding, clankity noise when shut off car
  65. 2006 G35x Donor Engine for a 2003 350z
  66. uprev help?
  67. Need to rebuild engine, where is the best place to look for a rebuild kit?
  68. Weird Oil Pressure?
  69. valve tapping question
  70. WTF is up with my Z?
  71. Oil catch can from ebay??
  72. 2003 350Z question
  73. The Infamous 350z Tranny!
  74. Questions about modded Z
  75. Is This A Joke?!?!
  76. Smell me!!!
  77. cooling plate, air diversion plate for 2008
  78. Oil help!!!
  79. Issues with wiring Mishimoto radiator fans.
  80. 3rd gear not smooth (AT)
  81. problems with Gt motorsports
  82. Why is this hose shaped an S ??? can it be replaced
  83. Oil catch install begins
  84. Installing Quaife, What items to freshen up?
  85. transmission problems
  86. first performance mod
  87. Extra capacity Oil Pan ???
  88. Replacing '03 track transmission with '06 G35
  89. Need to know??? (PCD Chip)
  90. Exedy Stage 1 Clutch
  91. Upgraded clutch for use with stock flywheel?
  92. Light Flywheel without Chatter??
  93. 2008 HR 6 speed getting a new tranny!
  94. Does the Z have an interference Engine?
  95. APS Fuel extreame kit
  96. 07 Auto transmission acting weird or normal ??
  97. buzzing sound!!!!!!!
  98. Where can I purchase Manual gears from?
  99. 08 lsd on a base 05
  100. REDLINE knock sound
