View Full Version : Engine & Drivetrain
  1. Installing a oil catch can soon
  2. Clutch Problems
  3. 2007 z jerking at 2.5 rpms
  4. AAM Oil Pan Spacer Drain Size?
  5. short shifter?
  6. misfire CEL
  7. Fluid Caps??
  8. Clutch Replacement Recommendations '06
  9. Good article on WPC coating
  10. Oil Pan Spacer
  11. Another Silly "What to do next" Post
  12. Greddy catch can
  13. No oil pressure on new NA build
  14. clutch probs?
  15. Oil pan spacer? which one help!
  16. new clutch?
  17. Quaife vs cusco rs
  18. I hate this dipstick - Anyone else have problems with reading oil levels?
  19. rev up vs non rev up
  20. Were to get motor built
  21. plenum spacer help
  22. Noisy Transmission after JWT Clutch install
  23. which type of fluids/lube should i go with?
  24. is this better or equal to oem?
  25. Which is the best Camshaft for 350z VQ35DE?
  26. does a rich & lean gauge works in a 350z
  27. Quest engine in 350Z?
  28. Clutch is rubbing something when car is cold
  29. Burning oil already?
  30. LSD for Base
  31. Ok serioius help here!! Rev up engine in my g35 with the non rev up ecu and harness..
  32. What's Inside this Engine? (Pics)
  33. who can i tell which diff i have?
  34. Air Intake Temperature
  35. Throttle Body Cleaning
  36. what in the world.. oil pressure sky-rocketing
  37. revup heads on a non-rev DE?
  38. what to do after some engine bolt ons etc...
  39. Clutch and flywheel combo
  40. pulley questions
  41. 06 Tranny Swap to 03
  42. Pulley Questions
  43. clutch.
  44. Battery / Master Cylinder Covers?
  45. Big Problem After Tranny Swap!
  46. Does the 06 pumpkin swap over to a 04?
  47. ecu numbers
  48. Spark plugs for Z
  49. Clutch noise? NOT GEARS GRINDING, NOT CLICKING
  50. Nissan Differential Gear Dimensions....
  51. Clutch Clicking??
  52. Need "03 350z" Owner Help
  53. doesnt a misfire throw a code?
  54. 2nd gear grind after long trip
  55. Car making weird noises when parked on a hill. *need suggestions*
  56. 04 stock injectors
  57. Rough idle, really rough acceleration and dead
  58. put my new clutch in and bam!!
  59. Slave Cylinder?
  60. JWT flywheel resurfacing
  61. rattling noise when switching off
  62. cracks on engine belt
  63. ACT StreetLite flywheel?
  64. Nissan ester motor oil
  65. water pump?
  66. unorthodox crank pulley. yes or no
  67. 2007 HR Transmission in a 2003?
  68. Clutch Related Issue. NEED HELP ASAP!!!
  69. Bleeding clutch problems?????
  70. How much have you spent to achieve...xxhp?
  71. Can anyone tell me if the Agency 3pc Pulley Kit is STOCK SIZE?
  72. Transmission friction/drag
  73. Clutch Wear Test?
  74. Adjusting a Nismo GT diff
  75. code po420 cats help please
  76. Clutch pedal interior squeak while pressing?
  77. N/A fun
  78. Berk High flow cats
  79. Calling All extreme APS fuel kit HELP
  80. 150,000 miles, and thinking about serious overhaul, advice needed
  81. Update on the clutch problem, advice needed.
  82. This doesn't look like VLSD does it?
  83. Nismo Diff Cover -Fully Polished - Pic!
  84. 06 clutch fit a 04 z
  85. NO 5th gear at all
  86. would an 08 catalytic converter fit an 03?
  87. location of the vin on the engine???????/
  88. Just got a Uprev Tune + Dyno on HR
  89. Auto trans is making awful grinding noises.. oh no.
  90. Over Torqued Spark Plugs?
  91. 350z Diff Cover, Need hi-res picture
  92. Is this clutch noise normal? (w/ VIDEO)
  93. Will the CD009 tranny fit an 03 Z???
  94. VQ35DE Cam Sprockets
  95. Clutch Questions
  96. Part Number Request Pls
  97. ACT clutch kit & stock flywheel doable?
  98. base to vlsd
  99. need help on clutch?
  100. Problem with TCS and Slip lights and sudden power loss
