View Full Version : Engine & Drivetrain
  1. has anyone converted there tb?
  2. Coil problem help pls..
  3. Popping noise.. please HELP!
  4. engine temps
  5. HELP engine rattle
  6. Ok, WTF did I break now?!?!!?!? lulz. Clutch/Drivetrain Problem
  7. a clutch problem?
  8. Oxygen sensor heater control circuit HELP!
  9. Pulling the air compressor
  10. F/I and 5at valvebody/shift kit
  11. Swapping 06 clutch for 03 ?
  12. P0011 & P0021 Intake Valve Timing Control code
  13. CEL/SES lights?
  14. Hometown Faves | Trusted Retailers, Distributors and Parts Bins?
  15. wont start. HELP
  16. Camshafts?
  17. HELP! Changed Oil. Now Temperature Hand is Jumping Up and Down
  18. Clutch Decision
  19. N/A Horsepower reality check
  20. Clutch Issue
  21. Looking for Pics of Polished Diff Cover
  22. Quaife LSD install issues?
  23. 03 to 06 Swap - CAN error / trying to pair key?
  24. New Clutch?
  25. Exedy Stage 1 CL and Lightened Flywheel
  26. drivetrain setups
  27. Dyno numbers seem low, let me know what you think.
  28. Grinding/Rattling with acceleration, but not when shifting.
  29. Clutch!
  30. Sometimes won't start
  31. Pleasantly Surprised
  32. Techmate Solar Charger?
  33. Final Drive?
  34. NATS Failure = 1900$ fix
  35. Are the Z transmissions ALWAYS a problem?
  36. 08z clutch sticks only 5k miles.
  37. I got a problem help i need advice
  38. serpentine and ac belts
  39. Rattle noise coming from engine bay?
  40. RPM suddenly drops down to 500 HELP!
  41. Borla Headers and Act Clutch kit Help please
  42. any one done a fuel return them selves?
  43. Stub Axels
  44. First Mod? Where to start?
  45. VVEL Modification
  46. New Built engine. coolant bleed??
  47. Bleeding slave cylinder. new jwt clutch combo
  48. Just switched from conventional to mobile1 full synthetic, and car feels NEW!
  49. Steering is harder!
  50. Pi-thon Locks, where to source?
  51. Which Tranny? Problems
  52. 6th gear grind
  53. Service Engine Light question. Please help.
  54. Goto supplier for OEM clutch?
  55. 1000 $
  56. OEM Engines...
  57. Dyno #s
  58. How do you like your pulley set up?
  59. Grinding sounds near front of engine!!
  60. buying a 350z block
  61. fuel gauge problem
  62. wiring/sensor mess! need help! techs chime in please!
  63. No 5Th Gear!
  64. NISMO oil cooler installation manual?
  65. Can I use REVUP engine harness for NON REV???
  66. balanced and blueprinted???
  67. Where to purchase DRIVESHAFT?
  68. 03 track quesions
  69. Nismo Diff Cover question
  70. For those who Installed a LSD on a Base
  71. Where to get 009 trans?
  72. Difference in VQ35DE motors??
  73. transmission problem in 03 350z? dealership problems
  74. Unorthodox installation
  75. base differential--» VLSD need help
  76. need help with p0430,p0420,p0300 CODES
  77. Anybody use Prestone Super Radiator Cleaner?
  78. SS Clutch line recommendation
  79. Grounding Kits for 07 Auto
  80. flywheel questions
  81. Jerk when switching gears.
  82. Engine Swap and Wire Harness
  83. Clutch Gone?
  84. axel help
  85. Clutch is gone, what to do now?
  86. Pulley tech help.
  87. Default Oil pressures
  88. looking for clutch
  89. Axle stub install
  90. How many teeth on a 3.7 final drive?
  91. another clutch problem please help!!!
  92. Cars stalls when shifting to neutral when driving...
  93. help ses light on and codes 0031 0051 0037
  94. Coil pack connectors
  95. Possible issue with TCS
  96. 03 Z clutch and tranny feels weird
  97. Engine ticking?
  98. Question
  99. 4.083 gears for my 5AT - Nissan part #?
  100. Should flywheel be replaced with clutch?
