View Full Version : Engine & Drivetrain
  1. Headers
  2. Infiniti FX45 Dual Exhaust Question
  3. Used Fidanza Flywheel/Exedy Clutch (Good/Not?)
  4. Differential Noise
  5. Power steering question for Auto-xer's
  6. Cutting "3.5 V6" Engine Cover to Fit...
  7. difference in clutch stiffness
  8. compression test!
  9. cold air intake
  10. PLEASE help with code P1274 after header install
  11. Valve body upgrade.
  12. Quaife 6 speed sequential box
  13. JWT clutch/flywheel missing parts???
  14. Clutch isn't coming up all the way? Help wanted.
  15. OEM fan relays and wiring location?
  16. General Question....
  17. need help with troubleshooting...
  18. Dyno results - 2005 (non-rev up) 350z
  19. Serious Transmission Issues
  20. Engine Noise
  21. New Product: Z1 VQ35DE Twin Plate Clutch Assembly
  22. Axle stub 38220-AR011. WHERE CAN I GET IT!
  23. need to buy a pulley set give me your opinion
  24. idling runs at 2000 rpm when started then decreases slowly, is that normal??
  25. Stock flywheel weight
  26. 06 rev up V2 replacement:: Mod and tune before or after break in period?
  27. Quick Question. Somewhat noob. About Nissan Courtesy Parts.
  28. 350Z for 3 Weeks....Oil Issues Already!
  29. Tomei VQ35 EXPREME HEADERS VERSION 2!!
  30. Exedy stage 2 engagement?
  31. Relieve fuel pressure?
  32. steering wheel making creeking noise?
  33. power steering lines FTW.. need help
  34. How much are the transmission losses % in a 350z
  35. Grind when shifting into 3rd - and only 3rd
  36. 4.083 FD VS Zex nitrous kit
  37. short shifter on a Z???? qhat do you think about it
  38. Which bearings are needed for a Quaife install?
  39. Need help!!!! 0021 code
  40. Dyno of my 03 at R/T tuning
  41. why is the cd009 tranny so much quieter?
  42. Nissan V6 Plastic "Engine Cover" Question
  43. '06 350Z MT - Oil Questions
  44. Tran’s problem second swap in a year
  45. Any one try these out
  46. Dropping the subframe to put the motor back in... HELP (Have free candy)
  47. Identifying or adjusting the nismo diff?
  48. Hydrolock Scare
  49. Custom ground wires
  50. Driveline/Tranny noise fix?
  51. defferential experts I need some help
  52. 04 350z hard to get in gear.....HELP PLZ....
  53. Sloppy/Droopy clutch pedal?
  54. fault code help?
  55. Installation Quaife LSD - need base model stub axles?!
  56. Oil pan bolt torque specs?
  57. clutch whining
  58. tansmission noise-sounds like blow off valve
  59. Stock clutch HP ratings.
  60. Nismo differential cover...does it work?
  61. MY03-05 VQ35DE NVCS Phasing Degree Angle
  62. Engine putters a bit when stopped at a light. Feels like it's gonna die
  63. Kaaz LSD
  64. Evap system question
  65. Just changed plugs...now possible issues...help!
  66. Mishimoto Radiators?
  67. Oem Upper rear diff mount
  68. Owm Upper rear diff mount
  69. RB26 can put in 350z?
  70. MID 300 horSePOWER without TT or S/C???
  71. how much is space is required under strut bar?
  72. Clutch Pedal Hard To Push Down
  73. 03 with rev up swap
  74. Coolant hose clamps (dress up recommendations?)
  75. Whumwhumwhumwhum noise after 4.083 gear upgrade?
  76. Aftermarket Clutch + Flywheel - clicking/grinding sound?
  77. Unorthodox Pulley
  78. Synthetic or regular!
  79. New Product: Silicone Heater Core Hoses
  80. problem installing cd009..need help asap
  81. VQ35DE Oil Filters
  82. Clutch Diagnostic Help
  83. Best location for the VQ...
  84. Ebay Oil Pan Power Enterprise Replica
  85. Forged Performance: 350Z HR ECU Flash with solid results
  86. Rear end
  87. Throttle Body Spacer
  88. Whats the size of the factory fuel feed hardline?
  89. What parts should i get???
  90. Help
  91. alternator mounting bolt nut?
  92. Run tranny cooler or not????
  93. Needs Help! Fans dont appear to be spinning fast enough.
  94. Gauge wiring help
  95. 110 Octane Racing Gas
  96. 5AT fluid question
  97. Hesitation issue with a HR.
  98. Spark plug help????
  99. 06 acting weird :/
  100. I cleaned the Throttle Body, now I'm noticing odd problems.
