View Full Version : Engine & Drivetrain
  1. I cleaned the Throttle Body, now I'm noticing odd problems.
  2. 350Z Torque Converter
  3. P0327 - Knock Sensor Replacement
  4. reset ecu
  5. clutch/flywheel noise?
  6. New Z - What is this thing?
  7. Driveshaft Vibration!!!
  8. Coolant line running to oil filter
  9. pushing down on shift knob..
  10. I need better fuel mileage..plese help
  11. CEL codes P1288 and P1289
  12. 350z motor gurus Help!! (Cam timing?)
  13. Clutch
  14. I'm having Clutch/Drivetrain Issues, unknown...please help with input or past exp.
  15. What kind of gear oil are you guys using on your MT trans?
  16. Edge racing High stall Torque converter (daily driven)
  17. Cusco 1.5 way LSD on a base model
  18. A good clutch at a good price?????
  19. Stronger axles..
  20. how to set timing?
  21. List of problems.. please advise.. HELP NEEDED ASAP..
  22. 03-06 transmission interchangeable with 07-08 HR?
  23. CD0 009 tranny question (help)
  24. Back in for tranny work
  25. 3.3/3.5 Pumpkin Question..
  26. Clicking noises while shifting
  27. Custom Stealbraided clutch line question
  28. reprogramming kit info plz :)
  29. Nismo Spec 1 cams
  30. 4.08 gears change, Is it worth it to change the Factory LSD
  31. What is that?
  32. whats the best lsd/ratio setup
  33. Request for DIY?
  34. Race fuel?
  35. How Long To Pull The Engine
  36. Adding oil cooler, can it be added between engine and vortech? sandwhich plate?
  37. Need some help with oem g35 diff
  38. vq35de kinetix intake plenum v+ 03-06 question?
  39. Remanufactured Throttle Body
  40. need help making a choice
  41. How the FK to Remove the Torque Converter
  42. Clutch and Flywheel Installation Woes: Check engine light and backfires...
  43. Order of mods; 4.083 final drive
  44. does anyone know how many quarts of fluid i will need for manual trans swap?
  45. Nismo thermostat, should I or not?
  46. What should I Do next?
  47. Trans differences 03,04
  48. Motor Build Question
  49. will a 05 g35 tranny fit in my 03 350z?
  50. When first start up and engine is could, whirring sound from tranny
  51. Lowering Engine Bay Temps: wraps or other?
  52. plenum spacer question
  53. Oil cooler without thermostat
  54. need a tranny for my 03...any thoughts..help
  55. looking to buy a transmission off of ebay..any thoughts?
  56. Need Help: My 03 randomly dies after starting up.
  57. Bought some kelford s1 cams for my non-revup
  58. SeaFoam? Good or Bad...
  59. Knocking sound during acceleration
  60. What Clutch and flywheel shoud I get ?
  61. Wanting Cams? HELP
  62. Autozone Deal: German Castrol + K&N Filter $30
  63. help with codes
  64. mods to realize the best 1/4 mile possible
  65. Soft clutch pedal, hard to get in gear after car gets hot
  66. GTR engine in Z350
  67. suggestions for stage 2 clutch
  68. 93 Octane with 10% Ethanol
  69. LSD Install Question with Video
  70. camshaft sensors revup vs non revup
  71. Standard EGT's for the vq35de
  72. Random power loss in '04 Z
  73. 350z Clutch Problem!!!!!!!!!
  74. Problem with VQ35 240z Dieing at Idle, please HELP!
  75. Vortech belt sheared, cut this harness.. help
  76. STILLEN setup doesn't sound right
  77. Noise after engaging clutch*****it's not the chatter~
  78. question about new Invidia N1 exhaust
  79. stalling problem at start..
  80. In tank fuel filter??
  81. 2005 engine cover
  82. OBD-II SES (Service Engine Soon) Trouble Codes
  83. Bad MPG?
  84. Need a clutch adjustment?
  85. Exhaust question...
  86. clutch recomendations
  87. Where to buy vlsd axle stubs?
  88. improper tuning? struggling past 100
  89. New clutch vdc light came on
  90. Rear o2 Sensors Needed?
  91. New engine from Nissan!
  92. Plenum Spacer Issues
  93. Just Purchased Injen SES1986C...install ?
  94. Painting Valve covers?
  95. Clutch/Flywheel Replacement
  96. help!! 350z missfire ********!
  97. What parts should I get to install lsd?
  98. Engine stops for no reason, needs help!!!
  99. Injen True Dual vs. Skunk2 True Dual
  100. Wideband Install Location on HFC
