View Full Version : Engine & Drivetrain
  1. Buddy's car won't start...oil and plugs story
  2. squeaky clutch pedal
  3. LSD question
  4. VQ35DE or VQ35HR?
  5. New SPEC Clutch...Car won't start???
  6. New Transmition
  7. Can a 06 rev up motor drop in a 2004 with out a problem?
  8. P1167, P1166, P1147, P1146, P0159 - Failed Inspection.
  9. Question Regarding Overheating
  10. Tilton Clutch Problem
  11. oil catch can legal or illegal??
  12. So i changed my oil....
  13. coolant bypass mod
  14. fans dead
  15. Coolant? Exhaust?
  16. 350z year 2003 clutch help!
  17. JE pistons
  18. Question about swapping pumpkins
  19. Carbon Fiber
  20. Intake Plenum
  21. Engine Torque Dampener
  22. Powerlab Spacer Install Idle Problem
  23. Clutch problems??
  24. Clutch Line Leaking On Top Clip
  25. What short shifter to buy?
  26. I need nismo lsd
  27. Question about putting lsd in a baseZ
  28. My car wont start , and cant figure out why ! not a noob!
  29. what can I add to my ride for more performance(info inside)
  30. HELP!! Check Engine Light after Bluetooth Install!!
  31. weird chattering noise from what i think is the engine
  32. Anyone Else Using Eneos Synthetic Gear Oil?
  33. Clutch pedal dropped to the floor...wont come back up
  34. fans
  35. 06 Clutch Pedal Stick
  36. Transmition rebuild
  37. Pocketrockets Racing?
  38. Clutch and Flywheel suggestions?
  39. CJM Entry Level RFS
  40. 2003 transmition rebuild
  41. Transmission synchro type
  42. ARC Differential Cooler Pro Choice Kit - ARC Whore Army
  43. Quick question about fuel gauge
  44. Topspeed a cheap brand?
  45. When was LSD available in the Z?
  46. Question on Cusco RS in a Base '04
  47. Need Help With Trans/Clutch
  48. Engine grind when I start the car and it's chilly out
  49. TRansmission issue?
  50. Oil test
  51. Is It My Differential, Transmission or Something Else
  52. pilot bearing sizes
  53. 06' DE vs 07'+ HR
  54. MY new power steering reservoir
  55. JWT Clutch & Flywheel Combo 350z
  56. 2006 base model Z
  57. Who hasn't had an issue with their '06
  58. clicking noise 60-70+ mph...
  59. 08z MT problem? anyone?
  60. Aasco flywheel questions
  61. single turbo any suggestions
  62. FEED BACK PLEASE!! CLUTCH KIT F1 any good?
  63. Dyno chart
  64. Transmission issues
  65. oil change 3 quarts left?
  66. Problems with engine/trans. will warranty cover?
  67. Post Your Meth Injection Tank Setups
  68. friction free 3000 engine treatment?
  69. help cusco strut bar and 5/16 spacer
  70. Need help..Service Engine Soon Light and Hard to start???
  71. 5AT update/news
  72. ran 269whp on a dynapack?
  73. Fuel Gauge Reading "0"
  74. 6MT Gearbox Dimensions and Weight??
  75. lsd question!
  76. OBD-II Adapter - 90 Degree Angle
  77. car wont start
  78. JapTrix Update
  79. Where to buy Molykote M77 Grease!
  80. drain plug
  81. eBay radiator shroud
  82. More Horse Power!
  83. 430+ Ft Lbs and stock rods?
  84. Larger than stock crank pulley?
  85. The "truth" about synthetic oil.
  86. Z1 motorsports Stage 2 clutch???
  87. 06Z w/ basics done, want to twin turbo, suggestions?
  88. wat are the odds of this happening?
  89. Decel hesitatation while coasting down in gear
  90. Affordable final drive gears?
  91. Cold start leak?
  92. Oil Cooler Question
  93. Nismo Differential/ Transmission/ oil cooler build
  94. Z1 racing stage 2 clutch and lightened flywheel for the vq35 motor?
  95. quick help--UR pulley/Gates belt part #
  96. welded lsd or spool?
  97. 06 Auto Convertible FD grears.
  98. nismo differential initial torque setting
  99. Brand New Z, MT 2nd gear issue?
  100. Radiator support question
