View Full Version : Engine & Drivetrain
  1. Radiator support question
  2. Is this an acceptable replacement for a blown fuse?
  3. how will i know tranny fluid
  4. messed up clutch/ when did your clutch go out?
  5. putting the HR motor on a 05
  6. G35 Engine into a 350Z
  7. I want at least 650HP in my Z!!!
  8. Idling and Rev issue
  9. weird noises on a BRAND NEW car... no idea what they mean
  10. Rant: the withdrawal lever pivot pin...
  11. AAM Hiring-Auto Tech
  12. My baby had her first big warranty work (transmission)
  13. Electric problem with my Z..dagnosis?
  14. Clutch chatter?
  15. Tranny grind in Neutral
  16. Engine Identification HELP!
  17. need new clutch
  18. Do not buy pulstar plugs!!!!!
  19. Is there anything wrong on my clutch
  20. APS vs Stillen Oil Pans?
  21. RB26 444CC injectors and A/F
  22. Differential problems?
  23. Trip to dealer for tranny whine
  24. HELP?! Unorthodox Pulley question
  25. smoking at WOT
  26. Loud noise from transmission
  27. PowerSteering Maintenance Fluid Change-INTERVAL NEEDED!!!
  28. How tough to change Pulleys?
  29. Spark Plugs
  30. hoping someone can hep me out ..
  31. Considering throttle performane mods?
  32. Sprint Booster Throttle Enhancer, Looking for Testers
  33. head gasket similarites ???
  34. Weird transmission noise..
  35. HELP. Oil pressue. Oil light question.
  36. Castrol Edge?
  37. what is the advantage of a 2 way lsd?
  38. Oil's
  39. What kind of HP should I have with these mods...
  40. How come when i shift
  41. diff question?
  42. Differential.... which one do I have??
  43. Problem solved with SEL
  44. diff question?
  45. HR Bottom ENd with DE Heads?
  46. Hks dli install guide??? Can anyone post up a pic?
  47. Forged Performance ECU Flash: In case you were wondering if tuning is required...
  48. 4.083 gears
  49. Pulleys!
  50. Size and brand of Stillen PS Cooler?
  51. Steering feels "loose"
  52. Anyone have an ecu pinout for a 2004 ?
  53. drifting some on ramps on the 405 but now my engine is toast..... ??
  54. Is my starter going out?
  55. Pumpkin' Swap
  56. Is your 2nd gear a little more 'notchy' than other gears?
  57. Going to the Dyno on Saturday
  58. 08 350Z Clutchmaster combo....
  59. Great site for ECU code explanations
  60. Rev-up: WHP w/ 5/16th,Mrev2,JWT s7 cams,Borla TD, reflash?
  61. Service engine soon light
  62. Leaking diff and rear axle clicking
  63. Ecu Question
  64. Track Model: "Close-ratio" difference?
  65. Cam Sensor
  66. 3rd Gear
  67. 2006 350z
  68. Clutch for pivot ball
  69. Auto guys in here...I have problems???
  70. Trans/clutch acting oddly
  71. Mods Mods Mods....
  72. Differential number help
  73. rear gears
  74. clutch partially engaged even when pedal fully depressed
  75. spec throw out bearing
  76. Service Engine Light
  77. Feels like slipping in 5th
  78. Dyno confirmation needed
  79. Cold weather + howling sound
  80. Please help! Dealer over filled my oil level, on a 06
  81. Let the Engine Build Begin
  82. 300zx single turbo
  83. Cosworth Plenum - Why Check Valve?
  84. help with wiring a coil
  85. Gas: not what octane, but what purveyor?
  86. 5AT GTM VB Upgrade
  87. Would like your advice regarding my transmission.
  88. Spark plugs~~~~~~~~~
  89. which vlsd should i get???
  90. VDC Controller??
  91. KP Technologies, 2 Step & No Lift Shift Module
  92. Speedometer stopped working! Help!
  93. Clutch problem..help
  94. flywheel bolt dimensions
  95. transmission oil
  96. Quaife oil?
  97. Going from Synthetic to Regular
  98. clutch slipping
  99. oil pan APS, what level oil ?
  100. Engine Noise
