- Feeling kinda slow . . . .
- CEL=bad 02 sensor
- I NEED A CLUTCH
- aam oil spacer question
- Transmission help 03
- Forged Performance is Hiring Again!
- Light Weight Flywheel, New Clutch
- Battle of Flywheels: NISMO vs UR
- Help accessing coil packs, spark plugs on passenger side.
- HR pistons in DE block?
- Lightest Clutch & Flywheel assembly (aside from tilton)
- LSD change also with Final Drive install?
- Where should I plug in my new gauges? Trans temp Air/Fuel and boost
- 06 Long block swap into an 03?
- HR engine
- Valvetrain noise?
- OH BOY WAS I WRONG!
- Strange Noise
- Clutch + Flywheel Height
- Reverse gear is too weak to go up driveway properly
- how to disable immobilizer for good?
- having really doubts on coming set up help me!!!NISMO?AMUSE??
- Gear install Parts Question?
- plenum spacer?
- One of my Coils went out.
- Next mod...
- NEED HELP
- plenum spacer thickness?
- weird noise?
- A better valve cover than OEM... search/ help...
- P0021 Code Again...
- Asking price for drivetrain?
- Clutch shot
- Age old question. Reduction of flywheel chatter
- Miles per gallon decrease! after spark plugs replace
- revup engine or?
- Pathfinder or Quest Alternators
- Looking for advice
- where to run wires for innovate lc-1 and gauge?
- Help my engine is knocking!!!!!!!!!!!!
- yay for new engines
- did all 06's burn oil?
- FOR THE MOTHER OF ALL TRANSMISSIONS
- Build Your Own 370z
- possible NA POWER
- Looking for some more hp
- How do I know my car is HR ?
- 2005 mt z and impossible to shift in reverse in cold weather
- dual mass or solid fly wheel
- Quaiffe LSD explain please!!
- walbro fuel pump and check engine light
- Clutch Pedal Concerns
- Transmission
- injen intake
- Jesus Christ my transmissino sucks ass balls
- Clutch pivot broke... Any recommendations?
- ACT clutch/flywheel installed
- Can anyone tell me if this is bad?
- Questions with LS1 swap in 350z
- clutch and flywheel question
- New JWT clutch and flywheel Problems
- Need more power HELP!!!
- tranny ?
- Twin Carbon Clutch on 540WHP
- clutch fluid line busted
- Neo Oil
- Cruise Control Problems
- APS Oil Pan Drain Plug Torque Spec
- Oil filter question...yes I'm serious.
- Several issues, please help!
- Radiator fans in hyperdrive.
- Engine Belts noise Help!!!
- Fuel smell. Weather related?
- Nismo VTC cam sprokets..?
- Lifter noise?
- Power Steering delete/bypass belt?
- Nismo Super Coopermix Twin Clutch is going out. Any replacement parts?
- ECU Reset
- Oil leak problems
- Need Mechanical help ASAP!!
- How much is to much?! "Oil Reading" Ranting!
- What is a Air/Fuel Ratio Sensor?
- Dyno Results with Osiris!! YIIPPPEEEEE!
- 02 sensor voltage issue
- Anyone have 3.9 or 4.08 Final drive videos?
- RevUp Upper Oil pan damage
- I hope this is the right section....
- New Motor UPDATE
- CJ Motorsports???
- Rev limiter increased from 6.6k to 8k
- went for a z; fell in love with a g
- Iridium vs platinum Spark Plug difference??
- ac compresor belt question???????
- * Competition clutch/flywheel?
- where is the thermostat located on a vq35de
- AMS Pulley Kit Install
- mrev2 on a non-revup
- Transmission Question
- Brake, VDC and Slip lit up at same time during acceleration
- 350z tranny question !!!!
