- Plenium Spacer for 2005 350z with TN kit?
- how do you tell
- Which mods should I first get?
- Is it necessary to drop the diff for the nismo cover install?
- serious issues need help!
- Blueprint and Balance (Engines)
- Throttle Body Spacer Quest!
- Clutch pedal not returning to the right position.
- Am I running too lean?
- stock block
- rev or non rev? rev or non rev? cant decide!!
- JWT Flywheel + Clutch
- Final Drive next OR Tune?
- Just a few things
- Which models have the oil consumption problem?
- Motor Swap Idea?
- Request DIY front HUB/Wheel Bearing assembly replacement
- Cold temp. tranny shifting problems
- Finally got my car on the dyno...
- AAM Dual Exhaust
- hissing noise coming from?
- greddy e-manage??? utec???
- engine noise
- Just Got Back From The Dyno.....
- Experience with used clutch/flywheel?
- clicking noise from engine
- Traction Control Off - Terrible Sound and Rear End Hopping
- which oil????
- Blitz Throttle Controller vs. HKS DLI II
- More HP For Under $1000
- Fuel pump Bucket
- Time to replace clutch/fly???help..
- Another transmission grinding question
- dual intake on 05 Z??
- New Clutch question!!!!Cant get into 5th gear!!!
- trasmission ? on a 07
- hmm wut to do...
- Engine internals. help.
- XO2 exhaust or HKS carbon ti exhaust
- Burned rubber smell... softer clutch :(
- check out my new oil cooler with V3 bumper and TN kit.
- Clutch-type Limited Slip Differential
- Today Dyno result!
- What mods to get........
- Dynoed my 06...
- 4.3 Final Drive Thread
- Checking the oil
- What clutch would make metal tinkering sound for 350Z
- Help with Mod list!
- oil pressure
- Hi I NEED SOME HELP
- Driveshaft compatibility 03-08
- 6sp tranny noise with clutch pedal released
- Does swapping FD void warranty?
- Weird Rattling
- cams & compression ratio
- Engine Pull Question
- Real high oil pressure!!!
- VDC, SLIP, BRAKE light all on???
- Running Rich
- New oil cooler
- New engine same problem!
- Accessport or MREV manifold as next mod
- ACT Stage 3 Clutch System
- 3.3 FINAL GEAR RATIO
- Car Not Taking OBD Scanner!
- New engine - idle problem
- I redline and my engine popped
- Trouble Starting
- Engine Wiring Harness *NEED HELP!!!*
- Cant solve clutch problem
- Ralli Art widband??
- Unorthodox Racing Pulllys Question!!!
- Anyone using Brian Crower Econ Rods?
- RPS Flywheel and RPS Sport Clutch with Street Disc
- Clutch kit issue??? HELP
- Pathfinder VQ35DE block same as 350z block?
- Carbon clutch roll call and quick review.
- Shifter Assembly Question
- I reached the 1st K
- SPEC clutch
- Clutch in, move shifter to first, car bumps forward?
- has anyone traded up because of oil consumption?
- Need help!! Engine is on but RPM won't go up
- Help me if you can!
- What's a good indication of...
- New Z owner - School me! -non revup, revup, HR?
- Underdrive Pulleys
- Finally dynoed my car.
- ACT Clutch
- Popping out of First Gear on Launch
- Will I need an ECU reset with these aftermarket parts??
- Simple question (with pictures for show and tell)
- 5AT Thump & Jolt: Normal?
- How can I tell if I have a Rev-Up engine?
- Engine exchange
- help plzzzz urgent
- 2006 OEM flywheel
- looking for advice on drive train
- 2006 consuming oil. Off to dealership we go
