- Light weight drive shafts?
- third gear grinding???
- Maybe Master Cylinder
- Oil temp gauge location
- Did something stupid I think
- Automatic Tranny
- Royal Purple Break-in Oil
- Need help asap!!! New spark plugs = smoky start
- Starter motor Question
- Dealer may have over filled my crankcase?
- Question about flywheel
- HKS Camshaft
- 4.038 FD from frontier
- Need Help w/ Oil Pressure?!?!!?
- diff breather needs replacing
- Anyone know OEM intake temp???
- Topspeed Pro 1 Engine Torque Damper
- Drive By Wire Observation / Question
- Clutch problems.. im in gear, let off clutch, doesnt stall out?
- Shift kit installation time
- ARC Titanium Hood Panel for only $166???
- Air filter / MAF related question
- Clutch
- Clutch Times
- Help please
- maybe a dumb question about aps single turbo kit
- rmp when car's cold
- Oil Usage On Non-revup 06 350z
- Can anyone help me figure out how to get the clutch switch to trigger a ground?
- F/I.....Exhaust?
- walboro fuel pump
- Largest Oil Filter
- Warning lights come on when driven FAST
- VQ35DE short block wieght?
- Temp sensor needle on the cluster fluctuating...
- hot start or bad starter?
- Ever seen THIS before???
- Minty Fresh!!!
- Strut Tower Spacer Question? (to clear Plenum Spacer)
- Exedy stage 1 clutch & ACT FW set up Q??
- How to calibrate o2 sensor
- scary sound
- 5th and 6th gear trouble, HELP!
- JWT Clutch and Flywheel???
- How hard can I drive my Z?
- do the vq35de have VINs??
- Anyone Advance timming with HyperForce System?
- Headers
- 07 engine in 03?
- Radiator Cooling Plate Questions
- strange click/rattle (not the usual throw out bearing issue)
- clutch noise
- starting car problem....
- engine splash guard?
- Need help with clutch pedal please.
- Timing and torque of VQ35DE engine help!!!!!!
- Transmission 2006 GT
- Is my clutch slipping?
- Upgrade Injectors on a "STOCK" fuel setup for Vortech Full Kit
- Knock from rear under heavy acceleration
- how to spot OEM LSD?
- Possible cheap mod for you VLSD guys
- Need immediate help - oil pressure
- Engine running Lean?
- What Valvespring Compressor do you have/use?
- Mobil 1 Extended Performance...15,000k?!?!?
- need help choosing clutch?
- I'm in love with my Cusco RS 1.5
- Q Regarding compression test..
- confused...
- Strange grinding when turning?
- put in fuel pump, car wont start.
- New Tranny - Stick is Higher
- solid motor mounts install
- High Oil Pressure?
- VQ25DET (Stagia) motor
- Can anyone identify these cams?
- Opinions Needed From The Experts!
- AC clutch issue? pls help!
- Rev up Motor
- Driving 5AT@@
- Connecting Rod
- Does anyone make a high stall for the A5?
- Stock injector size ?
- Rear Differential Question?
- CLUTCH/FLYWHEEL for 650whp?
- slight lurching?
- Sun grounding kit?
- LSD install in Base Model Z...
- fuel pump and wideband question
- Slow Clutch Response
- To rev up or not to rev up that is the question....
- AMS pulley set.
- Exedy VS ACT clutch?!?!
- 5AT Question@@
- 03 350z slow?
- Help! Odd burning smell
- Help, really weird vibrations/movements in the shifter
- JWT Clutch gone bad...need some help
