View Full Version : Engine & Drivetrain
  1. Anyone running an Exedy Clutch and ACT flywheel?
  2. oil consumption test
  3. 2007 oil dipstick
  4. Performance clutch for an '07?
  5. Differential oil... what do you use?
  6. swapping / replacing engine - a checklist?
  7. Need info on rev-up exhaust sprocket bolt ASAP
  8. Bunch of noises
  9. Weird Clutch/engagement
  10. Ecu Question!!!
  11. Belt problem easy?
  12. Fuel Gauge Acting Up!
  13. Clue me in on the "03 shifting problem"
  14. After clutch install, notchy shifting
  15. Shaking Shift Knob
  16. Engine Heat Soak
  17. Fuel Injector Cleaners
  18. Will an 07 08 motor fit an 03 Z
  19. Motor mounts
  20. starter?
  21. Is It Just Is or is This Crazy!
  22. Anyone have a cd010 tranny yet?
  23. clutch/flywheel for 700whp?
  24. Parts needed for switching to 6MT
  25. What is that "ticking" sound?..
  26. Tomei 2 way LSD
  27. Oil Psi
  28. Painting Plenium BLack
  29. Pulley questions
  30. Drivetrain slack
  31. Does this look good?
  32. AFR Monitoring
  33. Rev up engine?
  34. Metal piping intake manifold?
  35. GReddy Racing Titanium...on a Z?
  36. 4.083 whine at 40mph+?
  37. Z twin turbo drift car need advice......
  38. Where can I get a 4.3 final drive ring and pinnion????
  39. my 03
  40. am going to V8 my 350z
  41. another newbie with clutch question..
  42. Clutchmaster Stage 3 FX300 owner please come in...
  43. tach bouncing cause of back pressure
  44. Quaife Diff
  45. Manual mode Question 2nd gear
  46. New Gearbox Question For 03 Z Hep Plz!!
  47. Engine wire harness
  48. oil booster
  49. main seal and UR pulley
  50. Factory oil filter question
  51. Camshaft sensor location
  52. vk56de or rb26dett into 350z
  53. SAGA gauges
  54. Possible to to DIY install upgraded valve body on 5at?
  55. Replacing Flywheel: Will R-Tuned Nismo Work
  56. ACT Flywheel
  57. 3.3 lsd in my 04 performance 6 speed...
  58. little help on check oil light
  59. 03 6sp Gearbox Problem Help!!!
  60. JWT Clutch Friction Plate Question
  61. Correct Torque Specs L19 and ARP
  62. slight engine hesitation between 3500 and 4500
  63. ARC oil catch can V1 vent plug size???
  64. New cyclinder heads and camshafts
  65. Does anyone knows what brands make good LSD?
  66. NISMO LSD Lock-Up
  67. Clutch problems... new to cars
  68. Custom Oil Cooler Installed
  69. Short Shifters
  70. Good Piston Stop Tool and Crank shaft pully ques
  71. Blitz throttle control
  72. My clutch install went bad, help me Diagnose.
  73. A tune?
  74. Engine Build Started and New Garage!!!!!
  75. clutch and flywheel change
  76. Engine temp high, then check engine light - code U1000?
  77. Calling all 6mt Rev-Up Engine Owners..
  78. Clutch Pedal Adjustment Question
  79. anyone ever done a clutch for a 240?
  80. driving...then a hard buck...then service eninge light on
  81. God Damn It!!!
  82. UR pulley voltage problem
  83. Newb question about redline
  84. Wiring issue
  85. Gold Plenum?
  86. Ac line Removal
  87. carbon fiber drive shaft
  88. how to adjust idle?????
  89. Anyone find a bigger TB?
  90. Anybody with a 06 base model??? Help???
  91. Anyone have any actual drive time with a Clutchmasters FX700?
  92. My friend wants to buy this Touring 2003 350Z - Please read this guys and advise.
  93. Question about changing clutch fluid
  94. Noob Question about RevUp...
  95. 3.9 and 4.08 shims
  96. Eneos diff fluid put in now car feels weird!
  97. Oil Pressure sending unit
  98. Anybody else sick of the ethanol?
  99. highest safe rev limit for non-rev
  100. clutches for racing somewhat
