- Spec E-TRIM...600rwhp???
- Help -- Clutch Replacement, 31000 Miles?
- Technical Question about clutch
- weak dyno?? or am i crazy
- Trans problem in a 07 Z
- nismo thermostat. worth it?
- help with fuel pump
- which wideband?
- HR radiator core support in non HR car????
- DIY: Short Shifter
- AT making weird sound when going to reverse
- I need help identifying the VLSD
- problem with idle rpm and throttle
- Why I hate Dyno's
- 3.917 vs. 4.083 final drive
- JWT clutch and nismo flywheel
- Questioning my oil Cooler Install
- Hollllly Shi*!!!!
- 2004 Vs 2007 engines
- Aftermarket Clutch Opinions
- Strange noise.....
- Transmission problems
- PLENUM, INTAKE, TUNING and PULLEY questions!
- Engine Knocking
- Spark plugs for minor mods?
- The Build
- Identifying VLSD pumpkin
- ARC catch can question
- Knock sensor harness
- 03 engine wire harness help!!!!!
- Restore Engine Additive*****WARNING***
- Another Synchro thread, yes i searched
- spark plug problem? idle rough
- Final Drive Dyno
- Any good engine reassembly threads lyin' around?
- leaking fuel line
- NEED HELP ASAP!!! Transmission Codes
- p340 code and TCS/Slip light
- Dealer Warranty Clutch Replacement??
- oil loss
- Greddy Speed Cut Controller
- Can I change my solid motor mount like this??
- why LSD??
- How Important is torque?
- stronger c.v. joints
- Engine Problems?
- Koyo R core install
- 3.9 gear swap in A/T 350Z touring
- Replacement parts for AAM Fuel return
- 350Z pumpkin
- W/ all these swaps, why not an '03/'04 Termy motor?
- Trans Replacement Dilemma
- Would you use Quaker State oil?
- How much does it cost to swap the pumpkin ??
- OBDII codes: P0420 and P0430. And trouble with the performance
- knock sensor issue
- vlsd oil change problem...
- 3.9 fd on automatic
- clutch pedal
- how do i do the throttle body relearn procedure???
- whining noise?
- Clutches for street driving
- Octane for high compression. . .
- oil change date expired
- how do i test the fuel pump on my 04 350z?
- Pulse Plugs!!!
- g35 noise in 1st at 1,600 rpm
- Oil pan leaking
- AT Check light on... gear display off???
- Anyone around NYC or Long Island with an LSD upgrade...
- I think I am right
- Do Calif Z's have less power???
- Slave cylinder 2003 vs 2004+?
- ACT clutch and Flywheel a downgrade?
- NO START..... part 2.
- Has anyone had mods done to there 06 with the oil consumption problem???
- Question!!
- so I changed my spark plugs...
- how do I rest the ECU
- knock sensor, where is it???
- nano technology?
- Heat from Engine Bay
- what is a rev up motor
- Exedy Hyper Carbon Clutch Nissan 350Z
- Could Braille Battery Cause This?
- SouthBend Clutch
- What type of oil are you running
- AMSOIL: Where do you buy yours?
- 350Z Redlines??
- *Help Please* Can someone tell me if my stock oil filter cooler is on in this pic?
- Problem Codes (What could have caused this?)
- 06 Z A/T Question
- clutch for a 480hp supercharged Z??
- after installing my aftermarket steering wheel...
- does your 350zs fan turn on before starting?
- Stock clutch problem
- CEL and with it some problems :(
- Anyone have clutch fluid overheating issues with aftermarket headers in hot weather?
- Engine Oil Overfill... Problem?
- non-underdriven lightweight pulley?
